Trench Rammer.
would that knock 4" stakes in ? .... got a compressor that'd run that .. ex-tyre fitters service truck unit ... makes a lot of air. ... will run two 1" windy guns ... would want a long hose though .... 'kin loud bugger :LOL:
You can get a proper tools for that
yeh ..... but look at the price of the damned things .... would only need it maybe once or twice a year .... got a run to replace, but after that 🤷‍♂️
I’ve a petrol one, you can hire them cheaply
Or I’ll get rd to sending you that breaker for the jcb and you can side mount it and make a cup etc 😂
:cool: :cool:
second option'd be even better Giles .... thought you'd forgotten/changed your mind :rolleyes:;):)
:cool: :cool:
No it’s sat there on the pallet ready just been too busy to organise it
might keep the tilt grader as been enjoying the 5 ton version this week
:(:( .. 'spose it'll save me having to work out a plumbing set up for it ...... but got plenty of 12v Cetops sat about that, happened to fall into my lap :cool: :giggle::LOL:
Is there a particular trench rammer better than others? None local to buy so will need to order in but which brand etc… Bobcat? @Gunners
I like the 4 stroke wackers. Use a Honda engine. I think the same engine is used by other manufacturers too but defo a fourstroke over a 2. So much easier to start. Doesn't run as fast so don't know if you need more passes but a lot nicer to use regardless.
Bomag 4 stroke.... The bollocks.
I've just tried a Hydraulic Plate on the mini digger, But it's getting moved on. Shakes the digger too much and doesn't ram it in anywhere near as well.
I've a 2000's Belle and a Korean Belle Copy in the workshop atm to get going and then they will be for sale.
Pedrod355
Pedrod355
Seen a Bomag bt60 for sale, Will have a look into that if you think good, Bomag is very well known in the compaction field.
