Mogmans creations 🤔
What a job😩
Even with the cab dismantled the starter was way back to the right
Nearly thought I would need to remove the engine😳😳
But it’s out now what caused it🤔
Nothing else burned only what you see👆
What a job😩
solenoid not releasing properly and arcing at contacts ... wouldn't take long to catch fire ..... starter looks reasonable untouched or has that live broken off a pole on the end of the starter and shorted to earth ?
Grahams
Grahams
I had that on one of my machines. Smoke surrounding you as you sit there working didn't make for a good day. Luckily only melted the starter and didn't burn out the machine.
Steve
I remember years ago a poclain 75 had the exhaust blowing right at the starter like that and it melted the solenoid exciter wire to the battery live.
Good point, i had a telehandler do something similar
That's a blast from the past, a chieftain.
It will be some thing special to better your other projects:D
used to see a Chieftain or two quite regularly in Brightwells a few years ago :rolleyes:
looks a half tidy machine TBH ... assume that's a 4 tonner @Mogman ? servos?
