MacAulay Plant Services
Yes, really nice little system, flick a switch and it engages pump. We were thinking of getting itonto the speedo system so if your driving a buzzer will sound so you don’t forget to switch it off
yeh some sort of lockout would be good ... or a big idiot light on the dash, in parallel with the electro-clutch .... or the handbrake switch, when it's operated, switches a buzzer, (or disengages the pump) via a relay with the N/C contacts :unsure:
You probably wouldn’t want it connected to the handbrake on a hookloader. An annoying buzzer would suffice (y)
Rather than tapping into the Speedo line a micro switch on the gearstick would probably be easier picking up on second gear to knock it out
wee_gus
wee_gus
Back to this car again, this time another snapped link and the one beside also had a crack so may aswell replace it also, I have a suspicion this isn’t the end of the track issues on this machine.
Customer already advised he requires a full undercarriage including pads
Did you ever build your pin press for tracks
wee_gus
wee_gus
No, I’ve got some 3 bits 600x600x35mm plate ready to make something along with 2x 1mtr m42 thread bar.
Need to make something soon.
wee_gus
wee_gus
Few undercarriage replacements,
cat on 7k
Volvo on 7k
little Volvo 8t check valve been caught on a tree and snapped off.
wee_gus
wee_gus
Doosan dx224 in for complete undercarriage at 10k
She was a bit of a mare to do, heavy duty full length track guides
wee_gus
wee_gus
Some hoses made up for engcon installs
an old 814 in for new chains and sprockets, this machine has over 18k and in full use day in day out
burst pilot line on the joystick on this case cx130d
wee_gus
wee_gus
Bobcat E85 hydraulic fault, she blew the pressure switch for the hitch to smithereens.
Fully service and Thorough exam Carrie out
wee_gus
wee_gus
Bell B40 in for brake fault.. no hand brake pads left..
Heater fault also repaired
wee_gus
wee_gus
Doosan the decided it don’t like its final drive
wee_gus
wee_gus
wee_gus
wee_gus
Thanks for helping Jack out, Gus - I gather you did some large gauge pipework that was beyond the scope of his hand swager.(y):)
No problem at all,
He spotted me details in Gary’s machine, was the 3/4 320bar hose for the Doosan along with the 1/4 hitch hoses on the Doosan as the Doosan is 9/16orfs fittings
