Meflex zk Bomag wacker throttle cable
I need a new throttle cable for Bomag 30/38 td-3
Bomag dealer no help
It’s a meflex control arm and cable but I can’t find anyone who sells meflex stuff retail short of email them in Germany
Or trying generic throttle lever and cable any ideas
like your skid steer adaptor pick up in the back ground Giles ... what do you hang on that ?:cool:
its a set of jcb 3cx forks bought off @Mogman and added another pin hole for Takeuchi but its 2mm out so its there and has been there for a year now for fettling
bummer :(
What’s the serial number? Bomag have an online parts program
I can’t find it, or don’t know where it would be. Engine has plate etc castings have stamped numbers but nothing that stands out as serial. Where are they usually on Bomag wackers?
Still battling this
So bomag have part I need to get it working for £77 but they won’t sell it to me due to some internal rule! Want me to buy it all for £577!!!
Stupid
Was going ok then asked for serial number then the jump in price!
Still battling this
Stupid
could have a few made for that sort of cost ..... do you have the original one ... young fella round here is good at that sort of thing ... ;)
No but I’ve the cable and the gear it interacts with so should t be too hard to knock a brass one out
so it's a rack with three detents in the underside and threaded internally one end for the cable?
if you could draw it up - length/dia./ cable end thread and supply the cog that meshes with it (or better still borrow one to copy/get true dimensions from) it'd be quite feasible and not that costly either IMHDO
no little machine shops up your way ??
Rob65
Druid - The answer to “any little machine shops up your way” is I’m about a mile and a half away from Giles. 😀😀😀
Let’s see a drawing of it. Contractually, I’m only supposed to need to do my ‘Day job’ three days a week now so should start to have a bit more workshop tinker time. It might be something I could knock up. Depends what profile the teeth on the rack need to be.
well that's handy :giggle: .. do you have a horizontal mill Rob .. a suitably profiled cutter would be the main stumbling block to reproducing the rack or could be done on a shaper
I’ll get it from the yard on Monday and give you a bell 👍👌
I made one out of some hard pvc and files and dremel to test it but centrally drilling it without a pillar dril or lathe etc went wrong
Rob65
Don’t have a horizontal mill but figures since the gear does not pass across the rack just a plunge cut into the rack would suffice. Thought put cutter on a mandrel in lathe and mount the workpiece on the tool post.
Could probably do somthing on my vertical mill if I clear enough junk off it to be able to use it. 😀😀😀.
I don’t have any gear cutting cutters but they aren’t horrendously expensive or could maybe grind a single point tool and use a fly cutter set up.
