Best towable excavator (over next 10 -20 years)
FIVE 😳 mine only has 4🤔 stop, go and two hydraulic services
my last one did have 5 but the fifth one was for the magnet on/off
what have you got all them pedals for🤔 do you think it’s an organ😂😂
L-R ... rotate/VA-r, when it's on - VA boom - stoppers - reverse - forwards ... didn't count the horn button :ROFLMAO:
You’d need to have Devon toes to get the best out of one of those surely!
only if your feet were as wide as the cab and had a cleft in the centre to go round the steering column :ROFLMAO::ROFLMAO:
Er.. it's done 1000ish hrs and has dropped £10k makes it £10 an hour depreciation....
Jeesus how did I work that out 😂. Needs to drop in price a bit more then ..
In my defence there’s KX in Devon with 100hours. That’s about £28K though
Still toying with options. Thought I'd try a few different ones as no experience in 2.7t machines.
Just spent my last week in this one (or one like it) on hire. Came with 34 hours on the clock and I've done another 30 hours tidying up my future yard/ditching/scraping up/stoning and grading 130 ton of stone.
Thoughts.. comfortable and good visibility. Rollers on joystick SO much better than pedals. Tracks seems a bit slow and weak, swear my E10 is as quick. Loading stone with grader bucket will tip it fairly easy....extra counter weight is an option I'd look at if buying as well as blade float. I like the rear door being the fuel tank and filters. Makes everything very accessible.
Heaters were crap or broken, I'm not sure which. It seemed noisy in the cab but nothing to compare against so might just be me. Hydraulic hitch was a dream. Going to see if I can find a bobcat/doosan to try next time.
Had a rake bucket with it which was dead handy for sorting through a lorry load of mixed concrete waste.. but I would want to upsize as you cant seem to overload the bucket in that scenario.
I'm not surprised a full grade will have that tipping. The lack of arse on that is appalling!
Get yourself an arse unless you need zero
New Kubota KX2704 hi spec long dipper is 34K with hyd hitch (dealer added) 3 buckets and 5 year/2000hour warranty.
There is a 10 month old one with 100 or so hours in S.Devon for 28K.... and 4 years warranty remaining.
Yeah I've seen that £28k one on the facebooks- Im not too far from it, it's the basic spec model which might be fine for your needs? Personally I'd go for the new one- you were quoted same as me- probably same dealer beginning with V?
Yes V. One of their branches is only 2 miles away. Yes - having just looked harder, although its Hyd Hitch its not got the HiSpec Aux circuits.
