Auxiliary take off fittings
heritage machining
heritage machining
What are the standard auxiliary flat faced hydraulic fittings on a 1.8 tonne excavator
Probably 1/2" but have seen 3/4" on micros so.....
Id take a gamble on them being 1/2"
How are you sizing them? 1/2” thread can be on either a dn06 or dn08 sized coupling.
I can’t get my head around using 1/2” as a definition when it bears no resemblance to the actual fitting size?
well it's 1/2" BSP = nominal bore ..... it's the DN06/08 that gets my goat ... need a pretty comprehensive chart to make sense of the DN numbers
Is there some sort of chart for the dn specs? It would be handy to offer something up to a fitting to know what it actually is for mongos like me!
heritage machining
heritage machining
Jcb has always been 1/2in flow and 3/4 return.
They will run just fine on 1/2in return. Was always easier swapping machine fitting than attachments.
That's what it has at the moment dn06 on feed and dn08 on return bobcat has dn08 fittings I expect they are dn06 I will get a Vernier out and measure them
None of that makes any sense.
Hq16 hasn’t a thread identifier.
And hq12 can be 1/2” or 3/4@
And hq10 can be 3/8 or 1/2” but they haven’t even listed 3/8” there.
And they can all also be JIC or metric threads too!
This is what iso or DN standards are for ffs.
The DN or ISO standards aren't perfect either, as you know, the DN/ISO number only refers to the flat face coupling size, with no reference to its pipe size.
But agreeded, on second sight that chart is not the best.
I've always went by the body size, what I would class standard 1/2" body and 1/2" thread etc, I ordered a load of flowfit last year, 1/2"-1/2" and 3/4" - 3/4". what came was 1/2" body 3/8 thread. Thought a s**t, my mistake.... not to worry il still use them.
went back on line and made sure to order what I wanted..... only for the same thing to happen again :mad: called them up and explained the crack and they told me what I got was correct?
Now I know my fittings, and they weren't! asked a load of other guys what they would call them and all said the same..... so haven't bought any of flowfit again
