I messaged him about it to post it on here. No response
's why it's been listed for 17 weeks .... ain't far from me, but can't see it being worth the asking ??I messaged him about it to post it on here. No response
Prob the vat putting a lot off.'s why it's been listed for 17 weeks .... ain't far from me, but can't see it being worth the asking ??
opinions???????
I'd say you are bang on with that OO ...I am 99% sure it is a Powefab 300L - I think a fast tow T shape skeleton trailer could be bought with them. Info lower down on this page
bang on again OO .... my thoughts precisely ... would need to account for two motors - if you could match mounts/shafts/etc .. looks like they drive a chain/pair of chains in an oil bath per side, reading the bumf you put upCannot date from later than '95. Some of the motors maker used are said to be obsolete. Flowfit may find something similar but this may mean changing both motors unless a perfect match for cc per rpm, otherwise it would always wander to one side. Maker often used a single gear pump feeding a flow divider in the centre of the spool block, in effect a block on either side. The cc per rev of this pump is a starting point. I feel 3150 + vat a lot for an orphan unit 28+ yrs old that has a major fault, he should be offering it for spares in my view. I do not know this loader just talking of Powerfab driven design generally. They did often use Kontak hyd valve blocks. It really depends if the motor could be re sealed & if not how much for a new if indeed available.
My question why has he not fixed it before selling, he likely already has priced these options
assuming thats only lifting portaloos as thats some length of forks for a small machinebang on again OO .... my thoughts precisely ... would need to account for two motors - if you could match mounts/shafts/etc .. looks like they drive a chain/pair of chains in an oil bath per side, reading the bumf you put up
no way is it worth the asking .. it is however in fine fettle for its age and has probably spent 99% of it indoors.. compare it to this and it's mega dear
looks that wayassuming thats only lifting portaloos as thats some length of forks for a small machine
which one @Rob65Druid,
If you can get it at the right price you will wonder how you ever managed without such a machine.
I’ve got a Bobcat 463 and it saves so much lifting and carrying stuff that would otherwise go in a wheel barrow or cause me to struggle to lift in or out of the back of my truck.
It has forks on it nearly all the time. Can’t remember the last time I even put the bucket on it.
What weight can it lift ? What does it weigh ?Druid,
Sorry for confusion. I meant any small skid steer is incredibly useful.which one @Rob65... assume you mean the Bobcat??
My Bobcat 463 weighs about 1200kg and can officially lift 300kg in the bucket.What weight can it lift ? What does it weigh ?
