can't shift this
any ideas WTF it is @doobin ??
I messaged him about it to post it on here. No response
's why it's been listed for 17 weeks .... ain't far from me, but can't see it being worth the asking ?? :unsure:
opinions???????
messaged this bloke in the week ... tells me it now has oil pi**ing out of the one drive motor ... VAT's the least of concerns :ROFLMAO::ROFLMAO: ....... might go have a look at it and see where from and how much .. 's gonna be a real kicking point though :giggle:
Prob the vat putting a lot off.
O
Old Operator
Cannot date from later than '95. Some of the motors maker used are said to be obsolete. Flowfit may find something similar but this may mean changing both motors unless a perfect match for cc per rpm, otherwise it would always wander to one side. Maker often used a single gear pump feeding a flow divider in the centre of the spool block, in effect a block on either side. The cc per rev of this pump is a starting point. I feel 3150 + vat a lot for an orphan unit 28+ yrs old that has a major fault, he should be offering it for spares in my view. I do not know this loader just talking of Powerfab driven design generally. They did often use Kontak hyd valve blocks. It really depends if the motor could be re sealed & if not how much for a new if indeed available.
My question why has he not fixed it before selling, he likely already has priced these options
bang on again OO .... my thoughts precisely ... would need to account for two motors - if you could match mounts/shafts/etc .. looks like they drive a chain/pair of chains in an oil bath per side, reading the bumf you put up
no way is it worth the asking .. it is however in fine fettle for its age and has probably spent 99% of it indoors.. compare it to this and it's mega dear
O
Old Operator
I am pretty sure the above <1t Bobcat had its transmission case running longitudinally under the cab floor, all the chains &clutches were in there. The next size up (1.5t) had them in each side, hence they were easier to work on. The clutches in the bigger one were a sort of friction disc with radial grooves in. Once these linings wore to the point the grooves disappeared then they slipped as there was nowhere to squeeze the oil out (they & the chains ran in an oil bath). The smallest Bobcat was 1 speed but a few later ones had a dual primary belt drive with an electro magnetic clutch on each driven pulley, these primary clutches were dry. The friction discs for the 1.5t machine were still available recently but expensive - relining a cheaper option.
I.5t bobcat had a variable belt primary drive, think operated hydraulically
assuming thats only lifting portaloos as thats some length of forks for a small machine
Silversabre
Silversabre
Seems to be a few opico on ebay working for less than the powerfab, i know there still building the skidsteer and can do attachments
Looked at one for an idea
Rob65
Druid,
If you can get it at the right price you will wonder how you ever managed without such a machine.
I’ve got a Bobcat 463 and it saves so much lifting and carrying stuff that would otherwise go in a wheel barrow or cause me to struggle to lift in or out of the back of my truck.
It has forks on it nearly all the time. Can’t remember the last time I even put the bucket on it.
Druid,
which one @Rob65 :unsure: ... assume you mean the Bobcat??
Druid,
What weight can it lift ? What does it weigh ?
Rob65
Sorry for confusion. I meant any small skid steer is incredibly useful.
The machine I have is a conventional skid steer with a cab. The problem is you can only get in and out of it with the arm lowered so you need a second person if slinging a load on chains for example.
A stand on the back type machine would be much easier to use on yer own for yard work.
Rob65
My Bobcat 463 weighs about 1200kg and can officially lift 300kg in the bucket.
The hydraulics have plenty of power and the tipping load is about twice the rated load. Rumour has it that if you have a bulk bag to move you only need to shovel less than half of the contents into a spare bag and the little Bobcat can then lift and carry what’s left if you drop the bucket off. 😀😀😀
