Tilty thingy
Pedrod355
Pedrod355
I currently run a Steelwrist x04 for nearly 3 years & before that engcon ec04 for 3 years & before that a engcon ec02 on a 4 hose set up for 3 years. So what do you want to know
Ha everything!
What are you running the X04 on?
Do you have photos of unit as ones ive seen hoses etc don’t seem as compact/tidy as on other brands?
How do you compare it to the ec02 as that is what is getting replaced?
Presume your running S40? I would need S30, not sure if that is a option on the x04?
Any other info appreciated?
JerryRtilt
JerryRtilt
Have you always changed when changing machines, or have you had different Tiltys on the same machine ? Must be due to try Rototilt next ? :ROFLMAO:
Pedrod355
Pedrod355
I have try’d rototilt but they can’t offer a top hitch as there struggling to make them or some bollocks like that! And they can’t tell me when there new RC1 model will be available….
So they can only offer a direct mount old model Or me having to source my own top hitch!….. 🤷‍♂️
JerryRtilt
JerryRtilt
I reckon @CPS Aiden would sort you a top hitch no problem.
1RB
1RB
I’ve always had a Steelwrist s40 top hitch even with the Engcon’s below because they are so compact & the engcon top hitch had so much more height with the silly bosses they use.
I looked at s30 but wasn’t keen on a 3 tonner but think your fine up to 2.5 t
A few years ago I went out to Maskin expo in Sweden to see how it’s done properly & speaking to the people that use them rather than the salesman I learned a lot
The Engcon’s I thought were good but I kept braking them, some bits abuse & some bits not so but everything brakes it’s how you get going again that counts & that’s where engcon didn’t do so good
The first tilty ec02 was a 4 hose system on a Takeuchi tb228 & it got me going but diverting from tilt to extra service was a ball ache especially when you had the bottom quick hitch open swapping buckets you could rotate but not tilt so you had to lock hitch then pick up what you wanted then lock it on.
I run that machine till 4500 hours & then Ross (Sandhills plant) sold it for me
The next one was a Takeuchi tb230 with engcon ec04 but 2 hose with a svab controller which I learned from my Sweden trip no one in Sweden has a dc2 controller but all different makes run svab, Steelwrist, Rototilt, SMP, but call them there own different name.
I had the rotary coupling leak on that so sent it to the dealer for replacement & got it back after 5 weeks later still leaking after they just changed the o rings on the top & not inside it so I took it to Tewkesbury for a sit and wait & fair play they replaced it & got me going again.
I had problem with the bottom quick hitch during Covid & not a single person in the whole engcon world would pick up the phone so I phoned pat bullcock at Steelwrist & can you fix my engcon & he said it didn’t matter what colour tilty you got they all work about the same so he sent joe out the next morning & I was up & running again.
Ross sold that digger again at 4500 hours
This time I thought I’d better price a Steelwrist up & it was £1000 dearer than the engcon but thought the back up was better than price so put a x04 on a Takeuchi tb230 & it’s had a few problems like rotary coupling leaking again but this time I got the Steelwrist apprentice trying to fix it so it didn’t go too well so I removed it my self & took it to my hydraulic man in a tin shed & he changed the o rings as quick as I could make the tea
I’ve got another 1000 hours to put on this machine before replacing it but this time I’m thinking I’ll get the tilty rebuilt & put it on a new machine
Pedrod355
Pedrod355
Interesting comment’s.
Bottom line seems none are the best at communication/repair work.
What about build quality & power , Did you notice any difference there?
Keen to see your set up still if poss
The top hitch on the steelwrist I hired on a 6t kub was more compact than the engcon top hitch which suprised me when it arrived, never had a tape on it but deff lower build.
I tried to get steelwrist to price but local outfit are useless.
I seem to have an issue with the aux on my 4p ec206 at present, when i switch from tilt to hitch or gripper I have to push the roller a couple of times before it activates to open hitch or gripper, the gripper often tries to open first press , kind of comes open a bit then returns when i let go of rocker, not ideal but its under warranty and I will get them out to it over Christmas when it comes back to yard, the case dealer who fit it seems very responsive up to now.
JerryRtilt
JerryRtilt
Interesting stuff, i think rebuilding the tilty to fit on a new machine would probably be the Swedish way also, there must be so much more expertise available in scandinavia, there's just so few experienced people here at the moment, i've only really come across one in five years of Tilty ownership who i would say was completely competent and he started out with Pat Bullcock i believe.
Pedrod355
Pedrod355
Very true, Seems you need no experience to suddenly become a tilt rotator support Partner!
1RB
1RB
I’m in the woods at Disney land Paris & the internet is shite so it won’t let me post pictures for some reason but I’ll put some up when I get back
1RB
1RB
I don’t think there is a bad brand amongst them it’s always about the back up & all of them will promise you the world but when it comes to crunch time it’s who will stand by what they are selling.
I’ll have to take some pictures of my top hitch pipe work because even the Steelwrist guys were impressed by how tidy my hydraulic guy had got it. He makes up quick hitch install kits for quite a lot of the big dealers & manufactures
1RB
1RB
This is about the only picture showing hoses
also some of me removing the rotary coupling for a o ring reseal
it’s tight in there to get spanner’s at a few hoses but doable
1RB
1RB
I was having a go on this the other day but wasn’t keen on the kubota side of things.
There is no flow sharing between tracking & being able to do anything else, it’s ec02 s30 180 on a kx030 but I can’t drive it because the rollers are the wrong way for me & to change them on dc2 you need an android phone to connect to it to do it & every person I know including me has iPhones.
It’s only got 50 hours on it but it’s not set up right, the bloke that owns it had a go in my machine & can’t believe the difference it drives.
He’s had a priority valve that is for running a flail put in (£1500) to see if that sorts the flow sharing but now the tilty has all the flow & arm & tracks doesn’t have any 🤦🏻‍♂️
Pedrod355
Pedrod355
Does the steelwrist have a oil bath like rototilt ?
Engcon are taking out a DC3 operating system that will allow iphones to be used, But again no answers when this is due!
Does yours have control panel allowing flows etc to be adjusted?
Pedrod355
Pedrod355
The end of the worm drive appears to stick out past a lot, Is this actually the case?
Also lifting hook looks set well back also?
