Tilty thingy
It’s not a big hassle running a lorry, I used to run unimogs pulling my 13 tonners around but found it cheaper to buy and run an artic😳
Granted I have a yard now but 20 years ago just had my operating Center in a mates yard but parked in a farm yard did/do my own maintenance (and in 20 years only failed one MOT on a trailer that I was told was ok by one VOSA guy but failed by another one 😡)
Oh and I left school with no exams🤪 so can’t be that hard😉
I've seen the stuff you build, you under sell yourself. Not many people are as handy as you are.
SatS
SatS
Subject: Rototilt R2 + 3 Buckets for Sale
Hi,
I have a Rototilt R2 with 3 buckets, attached to my Kx060 machine. It was a temporary loan from Rototilt while my custom order was being made. Now, they're taking it back, but it's available for sale.
The price is £16K+VAT, including fitting and delivery. This is much cheaper than the new price of £22.5K+VAT. It's been used since August 2023 for under 40 hours and is in great shape.
If you're interested or know someone who might be, I can connect you with Tom at Rototilt for details.
Thanks,
Sat
Hi,
Thanks,
Sat
got any pix ...... why only 40 hours use in 13 weeks? :unsure::rolleyes:
SatS
SatS
I'll send the photos by tomorrow.
I have a good amount of land, which has been both a blessing and a curse. It's what led me to indulge in an excavator and rototilt. As much as I adore it, my main job often keeps me from enjoying it as much as I'd like—it's essentially a pricey hobby for me. I'm not exactly a novice; I've operated a KX027-4 that weighs 2.6 tons for around two years, clocking in about 400 hours. I've been a silent reader of these forums, soaking up knowledge from others' experiences. Now that I've finally signed up, I'm looking forward to contributing to the community.
Mines done about 300h !
So its racking up the hours, used to do about 1500hrs split fairly evenly across 3 machines, the 3t has only been out once and the 1.7t had never left the shed since tilty fitted.
I hoped it would be the case that we were trailing less machines about downside if you look at it that way is likely going to need to change machine much quicker than the norm !
SatS
SatS
Give the fella a break it's pissed doon for the last 13 weeks man!! ;)
Yeah, I've learned quite a bit about the dos and don'ts in the rain lately:
1. Avoid handling type 1 MOT—it turns into a porridge mess.
2. Wet soil waste in a trailer is way heavier (jumps from 12 to 14 tons for the same volume!), which got me a telling-off at the quarry.
3. Whatever you do, it's going to create a huge mess.
4. Sitting dry in the machine while everyone else is drenched does make you feel a bit guilty!
I dont suppose youve had a lot of experience to make a call but are you enjoying the 6t Kub ? - supposed to be an improvement over the prev gen.
SatS
SatS
The machine is truly exceptional—superbly engineered and incredibly powerful. I've primarily used it for grading, which really doesn't tap into its full potential. Yet, it's so smooth, and it was a game-changer when I cleared out roots from around 200 trees in a 4-acre woodland. That's when its strength really became apparent. Despite its size, it's surprisingly agile in confined spaces.
I also own a KX027-4, which has the advantage of being more portable for quick, small jobs across sites. However, I find myself choosing the larger machine almost every time now, even for tasks that don't require as much power, simply because it operates so much more smoothly.
Good to hear...the 056 was my favourite and the 060 is my goal.
Often think apart the transportation it's amazing how much more the 056 does for hardly any bigger footprint .
SatS
SatS
Absolutely, if you decide on the 60, definitely spring for the high-spec model. The additional circuit and the upgraded cab make all the difference.
Heard one or 2 people say the new 6t is smooth which is good to hear, ive had all Kubota for 7 years and they were v reliable, they were slightly older machines but noisy and uncomfortable compared to this 6t WN which a class above when it comes to operating, comfort,noise and smoothness, if Kub can get the operating experience to match the reliability then they will deserve the reputation they have 👍
The current configuration uses a direct mount with an S40. It's equipped with the ICS control system and a pair of Rototilt joysticks, if that's the correct term!
I will send some photo's tomorrow
Sounds a nice setup. If that was the temporary ‘loaner’ what have you had built/installed as the permanent setup out of interest (or nosiness if I’m being truthful!)?
SatS
SatS
Hi Guys
Photo's attached
Looks like I don't know how to read hour meters, apologies!, picture attached
SatS
SatS
So, I went all out for myself with a Rototilt R2 and a no-hose quick coupler. They actually don't make the R2 with a quick coupler as standard, but they agreed to custom-build one for me. Meanwhile, they lent me an R2 unit to use
you certainly do have an expensive taste in toys :oops:..... and I get grief for spending £15k on my 'Drema, plus all the toys I acquire, or build for it, from this lot :ROFLMAO::ROFLMAO: ... it's not a rehearsal ... one way track only :rolleyes:;)
