LGP tracks for a mini digger
Sledgehammer
Sledgehammer
I have a Bobcat E27z and would like to fit LGP tracks to it. Has any body done this or know where I can steel tracks and pads?
Astrak. Straight swap just the tracks gets you onto steels.
I’m gonna then make up some bolt on width extension pads, probably from 20x40 PFC stock. Looks like the track frame will support doubling the width.
I know you may have mentioned this somewhere else before @doobin but do you notice much improvement in the stability on steels over rubber?
Hard to quantify as the E27 is already very well 'planted'. But you've added around 140kg of weight at the very base of the machine, so it will have some positive impact there (although not on towing weight!)
The biggest difference is in the traction, pushing power and lack of sliding around in the shite. Incredible difference on wet muddy banks.
I’m gonna then make up some bolt on width extension pads, probably from 20x40 PFC stock. Looks like the track frame will support doubling the width. View attachment 53487
How’s it been on your trailer etc have you covered ramp in rubber we used to have a Jcb 803 on steels was tough on the trailer
Thomas7740
Thomas7740
Is it actually well planted or does it feel like it is as you only run 1.9t buckets on it?
They are pretty stable considering they aren’t far off zero tailswing, even with the big counterweight. This is a TMK 300 under a Rototilt R20 (which goes on a 6 tonne machine).
Would it lift about 95kg wrapped in a Palestinian flag?
Asking for a friend .
I've got an 8015 with a Haner attached that'd do it as long as you didn't wanna reach too far .... or a Cranab on the Drema that could handle bundles as big as you could make 'em :giggle::giggle:
