Best towable excavator (over next 10 -20 years)
If you are seriously interested in the KX027-4 then try and hold out for the hi-spec model because it has an extra aux circuit factory fitted. If you do ever decide to upgrade to a rotating grapple/grab then you will need this or you will need to pipe in a new circuit -- the issue with this is that the KX027-4 does not have a servo that can just be tapped into so you end up compromising -- this is what i had to do
Presumably not an option on the KZ61-3? What are the main differences between 027-4 and 61/3?
Yup. However, I've heard it said on more than one occasion that the 027-4 doesn't grade nearly as nicely as the older machine.
It was a Kx030 that i used that wasnt a patch on the old kx71 / 61 for grading.
Heard a few say it about that model.
Tbh my kx71 is feeling very agricultural nowadays - i would be going for a prop on the sticks , but it depends whatyou're used to or expect from a machine.
Pedal on hammer circuit.. correct. What machines that size have it on the sticks?
This one...mate of mine likes his tiltys.
Bucket was a tad ott 😀
But had rollers etc on the sticks.
Lovely little machine
100% this
Its hard to know, its not so much a falling knife anymore most of the drops have happened, we see some prices have stabilised or they are a few examples of things going up since the summer.
The main issue is we cannot see a route to market with kit. There is so little export market unless stuff is very cheap.
The next issue is the amount of fresh kit for sale is a huge change from the last 3 years where you couldnt get anything.
If you have a 2021 plate or newer the compition is manufactures with 0% finance 3 years warranty etc etc etc
Had jcb rep phone today left message do I need anything
Theres not a massive difference in the KX61 and the KX027 hydraulic systems. You have to go Hi spec on the kubota kx027 and kx030 ro get proportional rollers. You also need hi spec to fit a tiltrotator to as the hammer petal is linkage operated
Thanks for that. Not something that is on my radar.. (yet) so KX61 would be fine.
I must say that although a pedal is perfectly adequate for grab/tilt use etc a roller on the joystick is far nicer to use and leaves the feet to sit on the track pedals, not doing the tap dance😂
I tried a 027-4 briefly and seemed a well put together machine. Didn't spend enough time on it to do any grading but seemed smooth enough pulling it in an inch above the concrete- I don't think it would be a problem at all. Nice size can on it too.
I'm well impressed with my TB228 too. It's like the older TB125 to operate but alot nicer can and prop rollers on joystick etc. tis a bit weighty though for towing.
try a duck -- choice of five :giggle:
