Excavator mounted log splitter .
JerryRtilt
JerryRtilt
Does anyone have any experience / thoughts on this kind of log splitter, perfect under the Tilty i'm thinking, just wondering if the R1 would have enough flow through the aux.@cps
Trying to justify the cost just for private use, but i do hate swinging a axe nowadays :unsure: 4DF99D44-2F51-40AF-947B-DE4D62CC7C78.jpeg
  • AH700MPL-X Wood Splitter.pdf
  • log splitter.pdf
Trying to justify the cost just for private use, but i do hate swinging a axe nowadays :unsure: View attachment 53246
how much is it? .... bought my free standing/traccy mounted, new, couple of years ago and has been awesome ... can imagine that they're a bit of a faff lining up, etc., but can see the appeal too ... my Morso only has a small hearth though so have to keep me blocks 12" or less .... had it from a fella in Ireland and wasn't dear ... if it won't split, it'll chop it :ROFLMAO::ROFLMAO: for the real knotty bits(y):cool:
JerryRtilt
JerryRtilt
View attachment 53247 View attachment 53248
The one pictured is built in Canada, 1950.00cad = about £1150, had a price from Approved Hyd. for what i think is a larger version of the Canadian Splitfire £3200, (more than i want to spend) and the more primitive version in the drawing was £1400. Still more than i really want to spend :ROFLMAO:
Like the double action of the Splitfire, they have dealers in Germany and Holland but nothing showing here.
The idea of moving the splitter to the log from the comfort of the cab appeals .
The approved one has a big tonnage, which means a big ram, which you may find runs slightly slow on the R1,
On point id make, unless you are splitting huge rings, you will find it faster to use a hand feed splitter
understandable
these look a well thought out weapon
bought mine from a chap called Shane Mccarney .. can't recall what he was trading as ... IIRC was about 800 quid ... very good value and works beautifully - 16 tonner - not a lot stops it on tick over behind the Zetor ;)
TBH those digger mounted jobs wouldn't be that difficult to knock out ... plenty of ideas about to copy/replicate ... they'm alright if you have a good size burner, but chasing the bits about once they've been split down a bit could well become tedious
JerryRtilt
JerryRtilt
The smaller Splitfire model looks more like it, 3 1/2 x 24' ram ? recon you could be pretty accurate with that on a Tilty :unsure:
  • 3209 - Split-Fire.pdf
JerryRtilt
JerryRtilt
understandable
:unsure:
William127
William127
understandable
They look good, a big table is a massive help for comfortable productivity 👍
Youll get 20lpm roughly, which converts to about 5 gpm, so your on about 25 sec per cycle .
Unless your working with rings about 4 ft diameter i wouldn't bother with that style.
Anything smaller and you will just end up with the mrs holding them while you sit in the cab and mive the roller🤔😆
JerryRtilt
JerryRtilt
Maybe a bit slow, she doesn't have a long attention span at the best of times 😉 :rolleyes:
