but there are rules in place governing what can be done with / by the traccy brigade ...
e.g. get stopped with a load of muck in a dump - " where have you come from? - where are you taking it ? " ..
follow them and see if they are lying and nick them, seize the offending set up, then visit the site they claim to have come from, who by now are wondering WTF the cowboy in the traccy has got to :giggle: ... as an example
example two - digger on plant trailer same Q.s if the use/journey is not legit (ag./forestry - and can be proven) ... seize the lot - permanently
Or stop fleecing everyone with fuel duty and reduce it
Can I just throw something in about the lorry tractor debate.. in the south of Ireland it’s fully legal to run a tractor trailer set up carrying plant/materials/muck away for builders etc running on rebated fuel, no o licence requirements at all either. And both haulage and tractor brigade run side by side. Tractors must be tested for commercial use as well as certain types of trailer and must conform to commercial rules eg weights dimensions, the south can run at 46ton legally no paperwork required as long as whatever tractor you use is plated for it no bother work away
And yes fully aware it says agricultural but tractors can be and are used for haulage of diggers etc
Honestly I personally prefer the south’s rules on our industry it’s seems a bit more thought out and practical.
Just saying that alot of other countries use tractors legally and in line with competition, as said on here before they have their place and time where a wagon won’t fit or is more hassle to use eg access or something similar.
Personally I’m all for making life easier and not having to jump through numerous hoops made up by some office based twat that hasn’t ever come into the real world and tried doing the jobs we all do.
Common sense prevails
Found an afternoon free to scrape off a bit of wild ground at the end of our garage (we have some odd bits of land thrown in with our little semi as it was last one sold back in 2006). Planning to drop a full size gravel parking bay in there and turf round the edge. Tipper was full (wish it was bigger!) and filled a couple of tubs to fit in the front of the plant trailer so I could get cleared today. Don’t want to be making a noise on a Sunday as villagers frown on it.
Found an afternoon free to scrape off a bit of wild ground at the end of our garage (we have some odd bits of land thrown in with our little semi as it was last one sold back in 2006). Planning to drop a full size gravel parking bay in there and turf round the edge. Tipper was full (wish it was bigger!) and filled a couple of tubs to fit in the front of the plant trailer so I could get cleared today. Don’t want to be making a noise on a Sunday as villagers frown on it. View attachment 53204View attachment 53205
Hope that’s a tipper.
you need the high lift jack to get it started :oops::oops: ... some weight in that I'd guess :rolleyes::unsure:
Funny. I used the high lift jack to unhitch it as I've bent too many jockey wheels! High lift lives in the Dmax as its useful with the crane trailer as the rear swing down legs are a bit close to the floor on bad ground sometimes.
one can only assume from your stance that you very likely are :(
the obvious cost to others is that legitimate operators are unfairly competing against the do WTF they like-ers, to the detriment of their legitimate, law abiding, business (and those assigned with enforcing the rules don't seem to GAF. )🤬
went very quiet after this so went to bed, but was still showing online when I shutdown :unsure::unsure::unsure:
In fairness I've never managed to overload one of those trailers with soil or gravel.... And by f**k I've tried...... 10mm-0 granite/sand heaped just takes it over its payload.
2000kg of slate mulch fills it just under the sideboards.
