K
Keif
Is this play normal, if not can it be fixed?
Think it can be shimmed think mines got a little play but got more in the tilt hinge and ram mount bushes that needs doingIs this play normal, if not can it be fixed?
I saw the shims in the parts diagram but wasnt sure if they were for this problem or setting then gear mesh. There were also some wear plates listed.Think it can be shimmed think mines got a little play but got more in the tilt hinge and ram mount bushes that needs doing
Would if only a quick play have a go but definitely get it sortedI saw the shims in the parts diagram but wasnt sure if they were for this problem or setting then gear mesh. There were also some wear plates listed.
Should I tear this apart before using or give it a go like it is?
I guess the play in the engcon that @Keif has got is due to lack of grease ... the ec206 has one nipple for all apart from the gripper, its great for convenience but its not easy to see if grease is getting to all but the 2 tilt points front n back.
Is it possible for the grease not to be getting to the other parts and you not to know.... apart from if pipe union is off.
I think as you originally said, i'd still want to see old/dirty grease emerging from all the points i'd expect it to ? what's the recommended greasing intervals ?
Maybe not an issue![]()
a great deal of 'If,s' in that
Maybe not an issue
I think i'd still want to see old/dirty grease emerging from somewhere to be sure clean grease is going in ?a great deal of 'If,s' in thatas with all central systems
Same for me, the tilty can often get in the way when lifting most things tbh!I've got a breaker , mulcher and sometimes require that extra lift power lifting with my 5t mini digger so top hitch is a must
It’s a manual hitch , Can get them hydraulic thro as wellVery nice! Is that a manual or automatic bottom hitch?
That's very neat, compact and low build height, is it S30 180, BMC bucket ?
been around quite a while ... they do a unit on B20 that can be split .. top half gives you a tilt hitch .. bottom half gives you a rotator .. together you have a tilt-rotator ... works well with B20 as the build height is virtually zeroAnother brand...
Cant say I`ve seen them before.Marttiini Metal Oy
Marttiini Metal Oy on pitkät koneenrakennuksen perinteet omaava suomalainen rototiltti valmistaja. Tuotevalikoiman kuuluvat kallistajat, irtopyörittäjät ja rototiltit.www.marttiinimetal.fi
