Tilty thingy
I thought I could pin it on, right now machine has a manual quick coupler.
Did I mess up ordering? Lol.
have you got any hyd QH facility on it? otherwise you may need a QH solenoid valve, unless the control system can cater for it - may still need a QH valve though?:unsure:
K
Keif
No QH valve on in now, I'm ok with having to buy one.
I thought @Left hooker was saying that the top of the tilty would only work if I had a QH sandwiched between it and the machine.
nah .. that's a pin on ... can also get different size bosses to bolt into that hitch for different size pins
some I bought for an S type hitch I have, that was too cheap to leave where it was ... was like new
70mm dia bosses
50mm dia bosses
with S50 under it
K
Keif
I have ec206 sandwich the 6.5t and it hardly knows its on - it will be grand.
Thanks this is the first time seeing one in person. Also I was told it was coming with a 18", 24" and 36" buckets. Turns out the 36" bucket is closer to 48" and a proper scandi bucket, so that's cool. The 18 and 24 are rhinox buckets. I wish my excavator wasn't 3.5 hours away right now.
K
Keif
Do you mean do need a top hitch ?
Yeah. Isn't a sandwich setup where you have a top quick hitch then engcon, then bucket? So just wondering how often you run into a situation where it's worth removing the engcon.
Any bulk digging, pecker or ripper work I'd say. I run a sandwich tilt hitch and that's my take on it- not a tiltrotator op tho before anyone jumps on me.
K
Keif
Thanks.
I've got a breaker , mulcher and sometimes require that extra lift power lifting with my 5t mini digger so top hitch is a must
I have a flail with hammers that I know the tilty with have to come off for hoping I don't have to take it off much for other tasks.
If I don't end up liking the engcon I'm sure I can sell it and make a little $$
Thanks.
You'll like it 😉
