Bob the builder, can he fix it??
Maybe, steep learning curve though 🫣
No sniggering at the back, I never said I was any good! Filling in a load of ruts and reprofiling the gateway slightly so the water should go into the ditch rather than the gully.
Then I filled her up. Gulp. I swear I’ve barely used it but the tank was half empty- and it’s a big tank! Also fitted the new screw latch to the side panel and put it back on. I also replaced the springs inside the back window latches and lubed them up with dry moly on the slide and greased the bearings, which was a roaring success and hopefully the window will stop falling on my head now.
View attachment 50966View attachment 50967
