Yeah lots of old farm buggerment on the job we're on ...first proper day back after a eu style 3 week break :)
The handbrake is excellent. The footbrake isn’t. Normal?
Check on the dashboard as to whether it has auto clutch turned on ?? Depending on the age pressing the brake pedal should disengage the transmission. If not one of the buttons on the joystick will do it so you have to get use to hitting the button at the right time. Once you've got use to it your leg won't hurt as much.
And it allows you to rev whilst moving slowly to speed the hydraulics up.
When your a real pro you can do one foot on the brake and one on the throttle
toe and heel
toe and heel
Nah on telehandlers just put one foot full on on each pedal. They are designed for it. Some of the German machines you wouldn't even get your right foot on the break. The steering columns in the way
how many feet have you got ?? :oops:
William127
William127
I know the brakes on the telehandler at the farm where my yard is are so good a John Deere mechanic smashed the windscreen with his forehead!
And I'm really not joking, I saw it in the skip 😅 😆
Only two pedals on a jcb.
John Deere side boom telehandler? Notoriously sharp brakes known for catching people out.
The pivot steers where a much nicer machine
Canal Navvy
Canal Navvy
I wonder if that was the Matbro built ones with the full on hydraulic supplied brake valve/pedal 😁
William127
William127
Yeah side boom.
Been a good machine for them to be fair, 02 plate, they've had it about 8 years and it's got plenty of life in it yet 👍
like the old Citroens with a brake button on the floor ..... on or off for the uninitiated ... very light foot required :ROFLMAO:
Yeah side boom.
Surprising how many are still running. I drove an absolutely pristine one on an arable farm a few years ago. It only loaded grain lorries on a 1000 acre farm all its life. It still smelt new inside.
Also spent a lot of time loading bales with a pivot steer. Lovely machine to drive but the transmission needed an overhaul as would get very hot.
