Wacker dpu-100-70
My wacker dpu 100-70 has stopped going into reverse, worked last time I used it around Xmas guessing it’s electrical
pauses briefly when the handle is pulled back but then carries on.
going to change the switch see if that helps
tried some spray on it
anyone know anything about them, how the forward backwards works etc
T whiting
T whiting
Are they not hydraulic for the forward reverse like the little ones?? try linking out the switch if you suspect it or test it with a multimeter
looked in RS for anything similar ...... pretty std sort of limit that
No handle has a cam that acts on that switch, throttle cable and that’s it. No hydraulics
On your picture 4/4 with the machine stripped, to the rear of the engine on the right is a block with hoses coming out of it, on the engine side of that are two operating solenoids linked to your switch, swap the caps over, see if it changes direction!
The offending valve
Looks like it’s been getting warm for a while! All good now?
That the discolouration on it? Has been sat out in the scrap pike for a month after being changed but grabbed a photo when I walked past and saw it
I'd put it aside Giles .... coil might get you out of trouble sometime :rolleyes:
