I’ve a canycom s100 swivel dumper branded as a Kubota
I fancy taking skip off and mounting a protech p30 compact tractor post knocker on it. Giving 180 swivel and sub 1m width plus tracked ability and tow ability for a potential fencing job next year doing fenced footpaths so post and rail both sides so could sit in middle and do both fences without needing to be on the sensitive/good side of the fence.
The p30 is aimed at 36hp and up tractors max flow is 50/l min but quick look at new kubota 36hp shows 20/lmin is its flow.
The canycom is 12lmin on belt driven pump
Thinking this might not be upto the task , at least it wouldn’t be combined functions but I’d like to retain swivel and tip ram so you could lie it down to 45 degrees etc for transport.
Worse case I guess is power pack mounted where skip used to be.
I’ve a digger mounted p18+ and as handy as that is it’s not the same as working next to knocker in control refining post position etc
Will 12/min lift the weight quick enough to be usable I wonder.
