Jcb hydraulics
Jigsaw G
Hi I’ve got a jcb loadall 530-120 on a 1994 All hydraulics have given up with a noise being made, had new parka pump fitted and sprocket still no different. Any suggestions?
Hard to explain have got it on video but can’t seem to be able to post it
you need to load it to youtube, then put a link to it here with the chain symbol above
heritage machining
heritage machining
Has it got any electrical interlocks for example seat switch or on my bobcat restraint bar I had a dodgy bit of wiring that was causing my bypass safety valve to stay open so I could not lift the arms the noise sounds like when you try to turn too much one way on a power steering system
oil squeezing through a PRV (pressure relief valve)
heritage machining
heritage machining
Almost certainly prv or safety valve although I had the pump inlet pipe collapse on my digger once which sounded similar
