Jigsaw G
Hi I’ve got a jcb loadall 530-120 on a 1994 All hydraulics have given up with a noise being made, had new parka pump fitted and sprocket still no different. Any suggestions?
Relief valve relieving all the time might fit those symptoms.Hi I’ve got a jcb loadall 530-120 on a 1994 All hydraulics have given up with a noise being made, had new parka pump fitted and sprocket still no different. Any suggestions?
Thanks will ask my fitter to look at thisRelief valve relieving all the time might fit those symptoms.
Sorry where is that located as he’s off for a weekThanks will ask my fitter to look at this![]()
No idea mate but if your fitter knows what he's doing he should probably have checked this before replacing the pump!!!Sorry where is that located as he’s off for a week
possibly a piece of pump keeping it openRelief valve relieving all the time might fit those symptoms.
Aiden @CPS / @Mick-the-fitter / @jd6820 / @Shovelhands are your menSorry where is that located as he’s off for a week
you'd certainly hope soNo idea mate but if your fitter knows what he's doing he should probably have checked this before replacing the pump!!!
What noise are you getting?Hi I’ve got a jcb loadall 530-120 on a 1994 All hydraulics have given up with a noise being made, had new parka pump fitted and sprocket still no different. Any suggestions?
you need to load it to youtube, then put a link to it here with the chain symbol aboveHard to explain have got it on video but can’t seem to be able to post it
oil squeezing through a PRV (pressure relief valve)Has it got any electrical interlocks for example seat switch or on my bobcat restraint bar I had a dodgy bit of wiring that was causing my bypass safety valve to stay open so I could not lift the arms the noise sounds like when you try to turn too much one way on a power steering system
Power steering on full lock is what it sounds likeyou need to load it to youtube, then put a link to it here with the chain symbol above View attachment 50422
Thank you for your adviceAlmost certainly prv or safety valve although I had the pump inlet pipe collapse on my digger once which sounded similar
