I'm in the market for a new battery disc cutter, any recommendations?
I have a TS410 already, but fed up with the noise and fumes in confined spaces. It gets used a lot for cutting into existing clay drainage for new connections, no fun at all being in manhole/trench get blasted with 2 stroke exhaust.
It also won't cut 4" salt glaze in 1 hit - thought about going up to TS420 to get more depth but same issue with fumes.
I'm after a small battery SDS max breaker to go alongside it too (for breaking concrete off pipes etc.) so I can do most drainage off battery rather than 110v and 2 stroke.
I have Makita 18v battery kit so in theory that would be the logical brand choice but just checked and the twin 18v cutter only goes to 230mm which is no real use to me, I rarely cut slabs/bricks. Might be used for rebar but that's it.
Anyone used the below tools?
Twin 40v cutter 350mm
Makita CE001GT201 80V (Twin 40V MAX) XGT Power Disc Cutter 2 x 5.0Ah 40V Batteries & Charger was £1439, at D&M Tools.
www.dm-tools.co.uk
Twin 40v SDS max roto hammer
Shop Makita HR006GZ Twin 40V Max XGT Brushless SDS Max Rotary Hammer Drill (Body Only) at Toolden. Free delivery on orders over £50, 0% finance options available.
www.toolden.co.uk
Open to any suggestions
Cheers
