Pipefall gradient tool
JerryRtilt
JerryRtilt
Ours is glued 100mm not 110mm - Ive banged on at our supplier for bloody years to get the stuff with seals like we used to use in u.k ....well first few years he just said bugger off back to England if you don't like it, later as we spent a fair bit of money with them this turned into a see what we can do response,and finally we have (not sure of manufacturer) but blue fittings with seals, trouble is they are eye watering prices, so at mo the take up is slow and everyone carries on with the glued stuff.
That's interesting, with all the problems with pipe and fittings i think i would be happy to try glued fittings, do you have to chamfer the pipe and do you air test systems?
Another thing that's beginning to annoy me is nearly all the pipe comes in a special preformed banana shape, not sure if its the way my supplier stores it, i know they get it through Roudens, i just haven't got the patients to deal with the clowns there. :mad: Time to try someone else i think.
Roudens or your local supplier??
JerryRtilt
JerryRtilt
Local supplier is fine, Roudens branch here i find very hard work so i let the local supplier have the pleasure, price comes out the same with their terms and my blood pressure doesn't suffer as much :ROFLMAO: Although I'm not sure who its responsible for forming the banana shaped pipe🐒
See if you can deal through the Horsham branch with Adrian. Far better than the rest put together. And the banana lengths come directly from polypipe I'm sure as it's the same everywhere
Yes we chamfer the cuts with a grinder just to tidy them up, never really found a solution to a perfect cut every time, cut off saw a pita to use for every cut and little grinder takes some getting a tidy cut so give a quick tidy and chamfer. Quite like the look of those cut n chamfer in one pass disc's.
No don't test them for air, it's only soil pipe.
JerryRtilt
JerryRtilt
I remember Adrian being ok, it was his female colleagues ...... :mad: :ROFLMAO:
we bought 1 of these my previous thread a year or so back. Cut and chamfer in 1 hit. Not super fast but better than having to use different tools
They aren't worth talking to if they pick up the phone everyone I know just hangs up. And the yard bods are incompetent to. 5 times we have been sent d400 manhole covers instead of gully grates. Especially frustrating when they are delivering the gully pots on the same order
JerryRtilt
JerryRtilt
Yep that sounds familiar, the bigger they get the worse it gets, trouble is it can f ck up a job all to easily not to mention how much time is waisted on the phone:mad:
I’ve been sent a free new Pipefall from them and chamfer tool, I was very disappointed on opening it.
Not used it yet but will tomorrow, very different from original!
Not tried thier chamfer yet I have 2 chamfer tools already the sds type with cheese grater style cutters and the one with replaceable cutters
Original one gradient changed by sliding it very robust but can only be used on bigger bits of pipe
Nee one fixed block with different offsets
Are you meaning the Protectaline barrier MDPE? Usually specced for contaminated ground. Have to use specific fittings, not the normal ones otherwise the water can apparently get in between the layers.
That has an aluminium or copper inner doesn’t it ?
That's the 1 I remember
Their pipe chamfer tool is good, now it’s new so slightly unfair test but did a great chamfer fast today on cheap pipe.
Pipe fall is ok just feels light and flimsy
Fed back to him needs an idiot proof arrows on it as my guy had it wrong way.
On certain falls if on wrong side of trench it’s hard to see compared to the original
Original one feels like if you had to fight off a rampaging wilderbeast on site you could new one no way. Maybe 3rd the weight, section much smaller/thinner won’t survive a steeping on.
Metex is silver one
Pedrod355
Pedrod355
Metex is silver one
Which pipe chamfer are you thinking is better?
Currently the metex one is the favourite, my previous favourite was the 3 replaceable blade one as squared end as well which the metex does but throws a lot of shavings and you need good grip on pipe on short pieces can grab at the pipe as well if go off centre.
The metex squares up the end and isn’t as aggressive as the replaceable blade one.
Will do a comparison of the 3, the lads like the sds cup one but that’s because it’s easier on sh1te cuts
