Pipefall gradient tool
Also some of the fittings are terrible. We had a dozen polydrain chamber bases on site and broke 3 trying to get rockers into them, and the rest where a huge struggle. Then the risers where a pig to fit and didn't want to seal.
Have you tried different lubricants. I find the clear oil type lube makes it very difficult to get my pipe in a tight hole. Whereas the thick white creamy stuff stuff applied to the ring allows a pipe to slide in with ease.
We use the osma lube and don't think they go in like they used to
The black in blue MDPE will blow plasson fittings off unless you use the inserts. It's definitely inferior.
I always use inserts regardless what pipe . I prefer the plasson fittings to the all black ones . (Can’t mind the make) I can’t get the solid blue water pipe anymore from any local suppliers . I’ve seen the black stuff delaminate and cause a restriction in the pipe .
We still have solid blue here
never put one together without an insert ... false economy
@Giles and that's completely different design Vin
I thought it was . Did you post a link to the original one ? I couldn’t find it. I was told they were making improvements to it but I suspect this might not be the case . They have probably found a cheaper supplier
JerryRtilt
JerryRtilt
I hate the polydrain stuff probably 75% of the bases come with the seals not fitted properly and if you don't notice its easy to damage them, next delivery I'm going to check them all and send back any not fitted properly, don't see why i should pay fortunes for them then have to resemble the bloody things. Do yours come from Rouden pipetek?
Change your monika to "scruffy" !
Yeah they come from roudens they send them out as standard unless you ask for polypipe they have both in the yard and the amount of agro polydrain is it's not worth the price saving. rupipe and George lines have Brett Martin which seems the best.
Are you meaning the Protectaline barrier MDPE? Usually specced for contaminated ground. Have to use specific fittings, not the normal ones otherwise the water can apparently get in between the layers.
JerryRtilt
JerryRtilt
Another thing that's beginning to annoy me is nearly all the pipe comes in a special preformed banana shape, not sure if its the way my supplier stores it, i know they get it through Roudens, i just haven't got the patients to deal with the clowns there. :mad: Time to try someone else i think.
In the good old days :ROFLMAO: , i used to quite like putting together plastic drainage.
Ours is glued 100mm not 110mm - Ive banged on at our supplier for bloody years to get the stuff with seals like we used to use in u.k ....well first few years he just said bugger off back to England if you don't like it, later as we spent a fair bit of money with them this turned into a see what we can do response,and finally we have (not sure of manufacturer) but blue fittings with seals, trouble is they are eye watering prices, so at mo the take up is slow and everyone carries on with the glued stuff.
