G
Get Carter
Hi All,
I have a JCB 15c that works fine.
I have recently purchased a breaker but there is an issue when it runs.
It will start off as required but within a few minutes it will stop. Switch the machine off wait a few minutes and it will work but then stop.
I have to date replaced the return hose to a larger size as advised and also changed the solenoid control valve after being told it was faulty.
Everyone I've spoken to or witnessed it have said its the breaker.
Today I tried the breaker on a 16c. It works fine. The difference in the 16c is it has a higher flow rate 32L/min compared to 25L/min. The breaker requires a min of 18L/per min.
I'm going to change the filters and hydraulic oil then get a flow test undertaken.
Has anyone experience of this or what may be causing it?
Thanks
Thanks
