Where to buy ground mats?
I’ve got about 20 of these ones work well, few without hand holes are awkward buggers get used last
tinydigger
tinydigger
I’ve never tried to sell any so if you want some you’re wellcome
nick…
will work out how many i need and get in touch with you to sort out how much and when i can collect them in the new year if that is ok. Also do you think they would make good temp greedy boards for a trailer when i pull garden wase around on it?
Nick...
Nick...
Sure they would be ok for greedy boards but ideally need a frame for strength.
nick…
tinydigger
tinydigger
nick…
sounds perfect i already have a load of angle for the frames will be in touch soon
Looking for something not too heavy, just for using for muckaway piles and running the Sherpa or E19 across a lawn. Ideally want chequerplate one side and smooth the other. Any suggestions?
Still looking. ? I’ve got (maybe 17) brand new ones on the container roof. 12mm, 35kg each. Smooth on one side and chequer the other . I have the joiners as well. Will be VATN invoice and cheaper than anywhere else!
