Look similar to mine. Best for protecting surfaces. Wouldn't want to use anything heavier than a micro over a wet clay lawn with them.I’ve got about 20 of these ones work well, few without hand holes are awkward buggers get used last
will work out how many i need and get in touch with you to sort out how much and when i can collect them in the new year if that is ok. Also do you think they would make good temp greedy boards for a trailer when i pull garden wase around on it?I’ve never tried to sell any so if you want some you’re wellcome
nick…
Sure they would be ok for greedy boards but ideally need a frame for strength.will work out how many i need and get in touch with you to sort out how much and when i can collect them in the new year if that is ok. Also do you think they would make good temp greedy boards for a trailer when i pull garden wase around on it?
sounds perfect i already have a load of angle for the frames will be in touch soonSure they would be ok for greedy boards but ideally need a frame for strength.
nick…
was exactly my thoughts ....... for pedestrian traffic£200 each those things
They take vehicles in too. I guess they will outlast us being that heavywas exactly my thoughts ....... for pedestrian traffic![]()
not that often though ..... they'm some sort of matsThey take vehicles in too. I guess they will outlast us being that heavy
Still looking. ? I’ve got (maybe 17) brand new ones on the container roof. 12mm, 35kg each. Smooth on one side and chequer the other . I have the joiners as well. Will be VATN invoice and cheaper than anywhere else!Looking for something not too heavy, just for using for muckaway piles and running the Sherpa or E19 across a lawn. Ideally want chequerplate one side and smooth the other. Any suggestions?
