Asked on Facebook specifically about the et65 and top hitch and a fair few lads answered and there seems to be about 50/50 split in opinion so I guess it comes down to the work you do.
Quite fancy the detachable gripper....its 4k worth though so would need to spend more time on it than on the floor.
Here's my 2 cents on it.
We have customers that went top hitch for there first tiltrotators, one customer has alot now and everything gets direct mounted. He has a 22 ton machine with top hitch and I know for a fact that the tiltrotator has never been off the machine in over 4 years.
If you do alot of rock breaker work then go top hitch, if not then save the weight and the money.. the only other time you will want it of is if your digging narrow trenches, but by the time your down the width of the bucket you will want to widen/taper the top of the trench anyway.
It the last 12/18 months I'd say 80% of what we have sold are direct mount.
As for the gripper, they are worth their weight in gold! Especially on a machine of that size you will not notice the weight and the width will be no wider than the tiltrotators max width anyway.
The Rototilt gripper is removable, not quick release but can be removed...... I can be pretty sure you wouldn't take one of if you have it.
We have customers that would park the machine up if something happened the gripper rather than drive the machine without it
Expensive...... yes, you will have a fair bit of change left out of a selector grab for 4k. But from I can see of your work you will use a gripper. And with the R2 you have the option of using both.
