Kubota with Tiltrotator
Asked on Facebook specifically about the et65 and top hitch and a fair few lads answered and there seems to be about 50/50 split in opinion so I guess it comes down to the work you do.
Quite fancy the detachable gripper....its 4k worth though so would need to spend more time on it than on the floor.
Here's my 2 cents on it.
We have customers that went top hitch for there first tiltrotators, one customer has alot now and everything gets direct mounted. He has a 22 ton machine with top hitch and I know for a fact that the tiltrotator has never been off the machine in over 4 years.
If you do alot of rock breaker work then go top hitch, if not then save the weight and the money.. the only other time you will want it of is if your digging narrow trenches, but by the time your down the width of the bucket you will want to widen/taper the top of the trench anyway.
It the last 12/18 months I'd say 80% of what we have sold are direct mount.
As for the gripper, they are worth their weight in gold! Especially on a machine of that size you will not notice the weight and the width will be no wider than the tiltrotators max width anyway.
The Rototilt gripper is removable, not quick release but can be removed...... I can be pretty sure you wouldn't take one of if you have it.
We have customers that would park the machine up if something happened the gripper rather than drive the machine without it😄
Expensive...... yes, you will have a fair bit of change left out of a selector grab for 4k. But from I can see of your work you will use a gripper. And with the R2 you have the option of using both.
The price of a grab versus a gripper is a bit irrelevant to me really as rarely do grab type work.
Not really about the money either, the question is are they heavy and bulky enough to spoil the driving exp on a 6.5t and by the sounds of it their not.
Been at it a long time and on my own a fair bit and always without someone strong on the ground, so anything that makes life easier.
For what WE do seems like direct mount - gripper - s40 is the way.
Rounding up the figures a bit,for the gripper been quoted approx £3500
Grahams
Grahams
I would have thought a gripper would get a lot of use and the extra weight on a 6.5t machine would be negligable. If you had it and realised you had made a huge mistake they are removable on the rototilt so although you have wasted some money, you are not stuck with it.
With direct mount, unless you are doing lots of breaker or bulk work, why would you remove it? Again if you got direct mount and it proved to be a complete nightmare you could retro fit a top hitch, but I'm sure most people wouldn't have an issue. The extra build height and cost is in my opinion too much of a compromise for that one time you may want to take it off.
Interesting how the different configurations divides opinions even among really experienced fitters and users, not all of it dependant on application either.
I take my Rototilt off when using the tree shear (and also mulcher). It’s too restrictive to send the oil through to either attachment and gives more capacity when using the shear at full reach.
To be fair whatever you go for you’ll just always wonder wtf did I do without one?!!
Thinking back I don’t think the grippers were removable when I had mine in 2016? Either way I use mine to it’s maximum every time so every little bit of weight saving/bulk removed helps!
I wasn't even going to bring the tmk into the equation....I dont use it enough to spec a top hitch based around it and I guess it will have some extra versatility being able to tilt and turn , question is will it run through the unit ?
I wasn't even going to brink the tmk into the equation....I dont use it enough to spec a top hitch based around it and I guess it will have some extra versatility being able to tilt and turn , question is will it run through the unit ?
Yes, but you lose a bit of ram speed. They do other rams though if it is too slow.
Another fair point I should have mentioned 👍
If using hydraulic attachments that need a fair flow then a top hitch would be required. That said the R2 has one of the best flows in in range at 55LPM plus.
It will run flails and tree shears etc. But I doesn't have a case drain which is a slight let down.
It will yes, you might lose a bit of speed but would make up for it on versatility
extra gallery required in the rotary for that though = £sssss
Standard on the next size up, more to do with space I'd say
absolutely, but a small rotary with an additional gallery will add significant cost for it and the manifold on top of it
those Roemheld rotaries I bought for my VA-r came in four or six galleries - the six also had a case drain so seven really .. the six/sevens were twice the price and rare as hens teeth .. got one sat which I jumped on when it came up on fleabay .. new they're eyewatering prices :cry:😭
Grahams
Grahams
I run a much too big clamshell bucket on my small menzi and just pipe it to the breaker circuit rather than through the tiltrotator. Still get to tilt and 180 degree rotate either way - best of both worlds.
