Conventional tail swing minis
2590kg transport weight. So a bit of scope to bring for a few buckets etc on the trailer too. It also has a 4cyl 1.5l engine in it.
I wouldn't say the engine is any better than a 3 cylinder, although there would be scope to de-restrict it from the 26hp. Got that engine in my Multione.
Yeah. Although the chap who's digger it was also has 4 U27s which run the 3 cyl. He recked the 4 cyl in the kx27 was smoother and quieter, the 3cyl would throb at certain rpm and cause quiet a lot of cab drum. Just what he said. I think the 3cyl is also smaller cc in my mind I'd prefer a larger engine.
I went and had a go on brand new kubota Kx027-4 today. Didn't work it just spent a bit of time in someones yard. Definitely struck me as a well put together machine. It all looked pretty good quality to me and well thought out. Seemed smooth and hungry for work. I wonder why it isn't raved about more on here a nice transportable weight too with buckets etc ? Decent spacious cab with excellent visibility and most importantly a proper overhanging counterweight... Only thing I wished is that you could clean up against the blade without having to offset. Its also quite narrow at 1400mm but not always a bad thing ..
Had a price on 1 yesterday with rototilt funnily enough
No I wanted a comparison to the wacker ez26 price, I actually fancied the kx 30-4 but to heavy for the trailer
I've mentioned it before but I would recommend you try out à kx30-4 before you buy as my mates is horrible to grade with, you don't want your hard earned in something that's not nice to operate..esp if it's your main machine.
I’d sooner run about a touch heavy than suffer too small a machine for the tilty. Not saying the kx27 is, as I think it’s a conventional tail?
True but with the kx030-4 you'd be way over weight with a tilty too. Its not a problem I guess if you live in a reletively level area, but the amount of issues I've had getting my TB125 up steep mud and algae covered hills etc,
I graded on the concrete with the 027-4 keeping the edge an inch above the concrete and found it pretty smooth especially since I hadn't had time to adjust to it etc. The tail swing is the same radius between kx030 and kx27 but there's a 200kg difference so perhaps counterweight heavier and it's also 10cm wider.
The KX30 is I think actually 2800kg so not 3t. You've got a bit of wiggle room.
Yeah 2800kg and 2590kg respectively transport weight. That doesn't include a hitch but a direct small bucket, the Strickland hyd hitch on the Kx027 was 70kg which seemed rather heavy to me?
I'll just leave this here...love the kx027.
Surprisingly nimble and balanced that setup. Seriously capable for it's size.
Here's a question. Do any of these diggers now clean the grading bucket up against the blade. I was a bit surprised how far short the kx027 stopped short of the blade- a good foot I'd say. My tb125 will meet the blade quite easily
With a bit of offset I've found all diggers I've driven will do it? Why do people get so hung up on this as a thing a digger must do?
And your TB125 is a great digger, but they don't make it anymore and sadly like many manufacturers - they seem to forget how good the previous model was when designing the new one. Bring back the 125 I say - ideal combination of size, weight and arm reach.
Bit like Hitatchi's ZX30 - long may it reign over all as the best 3t machine ever made.....
Should start a thread really of the old and great machines sadly no longer with us
JerryRtilt
JerryRtilt
My vote for old and great no longer with us, would be Hitachi EX60-2:)
Its a progression thing. Imo everything should always get better. So when I buy something 15 years newer then what I already have now its a bit annoying to have to then compromise.
My perfect towable digger would be.
-2.6t
-35-40mm bucket pins
-Full counterweight
-Bucket to meet the blade
- min of 1.5l engine
- full offset boom to the left.
- space behind the seat to fit a patterdale terrier
-dealer within an hour
If I can find something that did all that I'd buy tomorrow.
Just wait eurocomach now do a 1.9t with a 3 piece boom. Wait for it to catch on and there will be no problems
