Looking at first pic that’s a 7n 140mm block under the 150mm of stone
Miss read, thought you said 150 on 100 below not 100 internal
Weird detail. Why is it suspended?
I've had a thumb from the moment I bought my first digger, don't like to be without itView attachment 44694She bobbed a bit I’ll admit that but I’m fully converted to thumb life
What machine is it on?I've had a thumb from the moment I bought my first digger, don't like to be without it
Although at the end of this recent job it all got a bit small and I could definitely see the advantages of a grapple, so that's on the shopping list![]()
That will be an expensive pump ...just priced up a small one to pump à small annex to a tankFull reach on the dx10 in some sh1tty back fill, mill converted 1996 ish this was old pit where waterwheels were some big old beams around. Trying to get a 2mx1.5m pumping station in![]()
£7k yepThat will be an expensive pump ...just priced up a small one to pump à small annex to a tank![]()
Case cx15, kubota kx36-3 before that.What machine is it on?
Normally if it's bearing on the footings it's because it needs to be suspended eg on clay ground with a void under to protect against heave.
If it's just a normal ground bearing slab on type 1 then why go to the extra effort?
Would it not be worth upgrading to the hydraulic one. I think I'd would find the benefit is lost if I had to get out of the cab to get it on the right position. Mine is flicked in and out constantly, even use it for things like hanging bulk bags off to bring the weight closer into the machine. RSL ones are good though. Don't even notice it on there.Case cx15, kubota kx36-3 before that.
Rsl engineering manual thumbs both times.
put a 3" strip of turf over it once laiduh oh. The base is 3” longer than regulations allow, and here’s a bloke with the rule book arguing the toss with my customers
Not joking !View attachment 44723
Too late! Looks like papers have been served!put a 3" strip of turf over it once laid![]()
Mixed 5m3 in ours last day or soToo late! Looks like papers have been served!
I wish I was jokingView attachment 44724View attachment 44725 mixing going well though, love this mixer for these jobs. Especially when it’s not me shovelling!
Just had a March increase and April the aggregate tax usually goes up too!These mixer buckets are starting to make more sense for smaller pours - the price of concrete at the moment!!!
