Jimoz
Gotta make a connection to a neighbours drain. I only just have enough depth so have got to come in flush although as i understand this is preferred with foul. Last time i had to do this i chopped in a flush 45 as pictured.
Thinking this time partly because of the outbuilding in the way I'm thinking it will be easier to come a couple of ft upstream amd connect the following osma base. I know it seems silly having 2 IC so close but both would have recessed covers and the lady will be ok. Im not 100% an IC is nessecary as if i connected a 45 immediately on the back of that chamber it would still be roddable? As it will hopefully be picking up a new dwelling and has a long 1.80 run my head tells me a chamber will be best?
What is the collective thoughs here?
Its hard work chopping out benching and altering pot pipework when i could just cut in a new section behind.
