Trying to clear some yard space!
Happy to talk offers..
Would PX a transcube about 1500litre.
What size hiab will it take? And models? or pretty flexible?It’s cheaper now, still in the way. I’d take a grand![]()
Take any size, but stability will be the issue. Had a Fassi 32 before, but basically anything that you'd fit on a 3.5 or 7.5 ton wagon would be more than enough.What size hiab will it take? And models? or pretty flexible?
You are going down a rabbit hole with the 1020kg that will be over the head of most!!with a decent sized hiab attached to it, it must be pretty close to the 1020kg mark![]()
know what you mean Shaun .... 1020kg is the max. unladen weight for a 3.5t GTW trailer, to be able to tow it with car/pick up/landy/rangey and license .... becomes a totally different can of worms if over that weight for all sorts of reasons. IIRC 1020kg is stipulated on your licenseYou are going down a rabbit hole with the 1020kg that will be over the head of most!!![]()
I went down this hole a couple years ago as my crane trailer is well over that weight, and printed off the sheets and had a natter with authority's. Over 1020kg empty weight is fine on B+E but falls under o-licence IIRC? There are exemptions, I think as long as Iam lugging it behind a dual purpose vehicle with a empty weight of less than 2040kg and within 100k radius (possibly other restrictions) then I'm okay (I think).know what you mean Shaun .... 1020kg is the max. unladen weight for a 3.5t GTW trailer, to be able to tow it with car/pick up/landy/rangey and license .... becomes a totally different can of worms if over that weight for all sorts of reasons. IIRC 1020kg is stipulated on your license
's madness really as you can happily tow a 3.5t fully loaded trailer behind a dual purpose/rangey/landy/etc.I have all the build figures somewhere, but yes it was about 1500kg plus I think? Crane and batteries and pump well over half that.
I had to collect it from Weston and come down motorway so I loaded it onto my flatbed tomake it legal as I was dragging it behind campervan. (Was worried about tyres as well) Daft isn't it!
it's not C&U though Rory, it's mainly license restrictions/categorisationIMHO it would fall into the category of engineering plant if you pushed it to court, which is exempt from alot of C&U regs
