Crane Trailer project l.
Trying to clear some yard space!
Happy to talk offers..
Would PX a transcube about 1500litre.
What size hiab will it take? And models? or pretty flexible?
Take any size, but stability will be the issue. Had a Fassi 32 before, but basically anything that you'd fit on a 3.5 or 7.5 ton wagon would be more than enough.
You are going down a rabbit hole with the 1020kg that will be over the head of most!! 😉👍
know what you mean Shaun .... 1020kg is the max. unladen weight for a 3.5t GTW trailer, to be able to tow it with car/pick up/landy/rangey and license .... becomes a totally different can of worms if over that weight for all sorts of reasons. IIRC 1020kg is stipulated on your license
I went down this hole a couple years ago as my crane trailer is well over that weight, and printed off the sheets and had a natter with authority's. Over 1020kg empty weight is fine on B+E but falls under o-licence IIRC? There are exemptions, I think as long as Iam lugging it behind a dual purpose vehicle with a empty weight of less than 2040kg and within 100k radius (possibly other restrictions) then I'm okay (I think).
with a decent sized hiab attached to it, it must be pretty close to the 1020kg mark :unsure:
I have all the build figures somewhere, but yes it was about 1500kg plus I think? Crane and batteries and pump well over half that.
I had to collect it from Weston and come down motorway so I loaded it onto my flatbed tomake it legal as I was dragging it behind campervan. (Was worried about tyres as well) Daft isn't it!
's madness really as you can happily tow a 3.5t fully loaded trailer behind a dual purpose/rangey/landy/etc. :mad:
IMHO it would fall into the category of engineering plant if you pushed it to court, which is exempt from alot of C&U regs
it's not C&U though Rory, it's mainly license restrictions/categorisation
SOLD it! A local guy took it to use as a mount for a stationery engine for shows. I think he is going to remove the legs and then remount the Jack's on the trailer. Glad to see it gone. Now to sell some other kit that's in the way! Should have been more organised 2 years ago when anything would sell easy, but like others I was too busy catching up on workload post covid...
