game changer JamesI’ve always had 4m, fine for me.
We’ll I get on fine with them, and with a separate wire feed I can’t see it being a problem.game changer James.... 4m wouldn't stretch far enough for most of our work
what does the other side look like Frank ?Best stick welder I've used, we didn't have a powerful enough power supply to weld more then 3.2mm was told when we bought it at auction after the ship yard closed that it was used with up to 8mm sticks
Similar to this, only our apparatus was max 450 A
It's not a welding device you carry with you under your arm
it was probably about 15 years ago that it was replaced with a portable 180 A device, but now I found pictures of what I believe is the same as we hadwhat does the other side look like Frank ?
Same as some power tools.I know this is a thread about inverter welders, but I have just found out this morning that the manufacture of transformer based welders, possibly over a certain size I think (basically anything half decent!), will be prohibited as from the end of this year! So anyone wanting a large capacity single phase unit will be disappointed.
More eco bollox
lovely .. pleased to see it has the swivel spigot for the wire feeder on top ... makes a lot of difference to convenience .... My Cifis had it and also made a swivel for the mobile mount trolleys we had under our wire feeders, as per previous pix 14-12-22Turned up today, not finished setting it up yet, but very pleased with it.
View attachment 42538View attachment 42539View attachment 42540
The swivel mount and castor kit was an optional extra, not a lot of money, like £35 iirc, so well worth it. Wish I’d got the swivel kit on the 3ph machine I have which is virtually identical to this. Probably something I can make or even buy the parts for maybe.lovely .. pleased to see it has the swivel spigot for the wire feeder on top ... makes a lot of difference to convenience .... My Cifis had it and also made a swivel for the mobile mount trolleys we had under our wire feeders, as per previous pix 14-12-22
I'd try and store the umbilicals on the trolley James ... uncoil as you walk away from the power source with the wire feeder, as you need .. on the base unit you have to uncoil and then walk away ... plus you can rotate the trolley to cater for getting twists out of the umbilicals ... PITA on the base unit .... the Cifi trolleys were made square as the feeders rotated and needed the trolley to be stable in all directions ... some of my other trolleys were wire feeder shaped as they didn't rotateThe swivel mount and castor kit was an optional extra, not a lot of money, like £35 iirc, so well worth it. Wish I’d got the swivel kit on the 3ph machine I have which is virtually identical to this. Probably something I can make or even buy the parts for maybe.
I liked the look of your mobile mount trolleys, if I had space then I thinking I’d do something similar, as it means you can easily make provision to store the umbilical, but without the space I really need to keep things compact. So I’m in the process of making up some sort of storage frame that I can attach to the back of the machine to hang the umbilical and torch etc.
tesco trolley castors were the best free rolling ... were always finding 'em chucked over the fence in the yard
View attachment 42545 View attachment 42547 View attachment 42548View attachment 42546
I’ve been pleasantly surprised with how well my 2 roller tech handles a 5m lead with 1mm wire.We’ll I get on fine with them, and with a separate wire feed I can’t see it being a problem.
My use of 4m probably stems from my first Mig, with only 2 roller drive 5m was not recommended at the time.
TBH it's only the 0.6 that ever really gave me prob.s with 2 roller feeds ... but I still run 5m torches on it, just make sure there's no twists in the lead/conductor.I’ve been pleasantly surprised with how well my 2 roller tech handles a 5m lead with 1mm wire.
What’s the benefit of the umbilicals? What am I missing? I just have the welder on a sack barrow type trolley along with the bottle and take it to where it’s needed.
