decent inverter deal
game changer James ;) .... 4m wouldn't stretch far enough for most of our work
We’ll I get on fine with them, and with a separate wire feed I can’t see it being a problem.
My use of 4m probably stems from my first Mig, with only 2 roller drive 5m was not recommended at the time.
Bucket on wheels
Bucket on wheels
Best stick welder I've used, we didn't have a powerful enough power supply to weld more then 3.2mm was told when we bought it at auction after the ship yard closed that it was used with up to 8mm sticks
Similar to this, only our apparatus was max 450 A
It's not a welding device you carry with you under your arm 🤪
what does the other side look like Frank ?
Bucket on wheels
Bucket on wheels
it was probably about 15 years ago that it was replaced with a portable 180 A device, but now I found pictures of what I believe is the same as we had
I know this is a thread about inverter welders, but I have just found out this morning that the manufacture of transformer based welders, possibly over a certain size I think (basically anything half decent!), will be prohibited as from the end of this year! So anyone wanting a large capacity single phase unit will be disappointed.
More eco bollox
Same as some power tools.
Lamello stopped producing 1 of theirs a year or so ago because of this s**t.
Also I think vacuum cleaners same
lovely .. pleased to see it has the swivel spigot for the wire feeder on top ... makes a lot of difference to convenience .... My Cifis had it and also made a swivel for the mobile mount trolleys we had under our wire feeders, as per previous pix 14-12-22
The swivel mount and castor kit was an optional extra, not a lot of money, like £35 iirc, so well worth it. Wish I’d got the swivel kit on the 3ph machine I have which is virtually identical to this. Probably something I can make or even buy the parts for maybe.
I liked the look of your mobile mount trolleys, if I had space then I thinking I’d do something similar, as it means you can easily make provision to store the umbilical, but without the space I really need to keep things compact. So I’m in the process of making up some sort of storage frame that I can attach to the back of the machine to hang the umbilical and torch etc.
I'd try and store the umbilicals on the trolley James ... uncoil as you walk away from the power source with the wire feeder, as you need .. on the base unit you have to uncoil and then walk away ... plus you can rotate the trolley to cater for getting twists out of the umbilicals ... PITA on the base unit .... the Cifi trolleys were made square as the feeders rotated and needed the trolley to be stable in all directions ... some of my other trolleys were wire feeder shaped as they didn't rotate
tesco trolley castors were the best free rolling ... were always finding 'em chucked over the fence in the yard ;):giggle:
Picture_0149.JPG 2014-03-07 12.46.19.jpg 2014-03-07 12.57.30.jpgtransmig 600 & TF20.JPG
View attachment 42545 View attachment 42547 View attachment 42548View attachment 42546
Great ideas, Graham, I’ve no doubt. But as I said, I’m tight for space at the moment, so coiling the umbilical on the base unit is what I’m going for, I also don’t need the ability to wander around the workshop using the full reach of the umbilical on a daily basis, I’m not a professional after all. Maybe later, when I’ve more space and setup better, I can make something like you had, but for now I’ve got to compromise.
I’ve been pleasantly surprised with how well my 2 roller tech handles a 5m lead with 1mm wire.
What’s the benefit of the umbilicals? What am I missing? I just have the welder on a sack barrow type trolley along with the bottle and take it to where it’s needed.
TBH it's only the 0.6 that ever really gave me prob.s with 2 roller feeds ... but I still run 5m torches on it, just make sure there's no twists in the lead/conductor.
the benefit of a remote feed unit is portability ... for instance if you're working inside something, like a truck body or a big tank (used to make quite a few), or a boat hull. you don't have to have the whole set with you - or the bottle, but can easily deal with the bottle with a long hose and leave it tethered to a wall (where your power socket is) ;)
