bought this MEK 4 wire feeder to replace a BOC unit that died ... was a lovely thing to use, with a Transmig 600A rectifier unit on t'other end ... 4 roller, soft start, nicely variable burn back .. was the Mutt'sRunning an ESAB mig as well at work. Never tried it on anything heavier than 1.00 mm wire. It came with a spool of ESAB wire, think it was nickel coated ER70 and it would not run it, back on the copper coated and again, runs a treat. Gun gave out at low hours but we’ve now got a Parweld torch and that’s improved things no end - not least cheaper consumables.
also had a quite old Esab 200 rectifier unit, which I put a sterling 2E on the front end of ... ex training college power source ... was/is (kept it and its original wire feed unit) a superb thing to use and at one time (in its day) was the best thing available for ali MIG work
