decent inverter deal
Running an ESAB mig as well at work. Never tried it on anything heavier than 1.00 mm wire. It came with a spool of ESAB wire, think it was nickel coated ER70 and it would not run it, back on the copper coated and again, runs a treat. Gun gave out at low hours but we’ve now got a Parweld torch and that’s improved things no end - not least cheaper consumables.
bought this MEK 4 wire feeder to replace a BOC unit that died ... was a lovely thing to use, with a Transmig 600A rectifier unit on t'other end ... 4 roller, soft start, nicely variable burn back .. was the Mutt's
also had a quite old Esab 200 rectifier unit, which I put a sterling 2E on the front end of ... ex training college power source ... was/is (kept it and its original wire feed unit) a superb thing to use and at one time (in its day) was the best thing available for ali MIG work
... I see that has a roll of bright wire on it Bri :rolleyes:
View attachment 41636 View attachment 41637
View attachment 41639 ... I see that has a roll of bright wire on it Bri :rolleyes:
What's in the cab under the vice?
just a 4 cupboard work bench I'd acquired from some sale -- various hand tools/big spanners/etc., in them and 3 vices on top .. only pix I can find :unsure:....
locks were a waste of time for anything other than light fingered customers .. plenty of lock opening gear sat about for nocturnal visitors :rolleyes: ...... but the alarm system f**ked them :giggle:
Phelans had one of these when I was on for them on a few jobs in Cambs & Northants. I wedged it in their transit pick up and dragged it thirty miles to pre-empt the floor of a 637 becoming completely detached.
The motor - dyno one I used at British Sugar had the ac motor above the dyno, don’t think it was a Lincoln. I have used those bullets in the past, without knowing what they were called, better arc than any large inverter imho.
The solid wire that came with the ESAB was coated, not Bright wire. Salesman said we’d never buy another roll of copper coated. Couldn’t get on with it, but it was better than Kennedy’s own brand. Didn’t know gouging wire existed until then. That was interesting about the Parweld being a Binzl copy, explains why one of my colleagues was adamant it was a Binzl until he saw the box. Do the tips swap over?
just bought 50kg of ESAB 6013’s, came to over £600, nearly double/kg two years earlier. We use far more Bohler 7018’s and they haven’t increased anywhere near that.
like this Bri ?
the old Esab 46.00 Miltrodes were a lovely all positional 6013 ... Oerlikon Fincord M weren't a bad second ..... neither were ever cheap though :rolleyes::( ... the Bohler weren't that easy to get a hold of 'round here
........, explains why one of my colleagues was adamant it was a Binzl until he saw the box. Do the tips swap over?
forgot to answer this one ... two sizes of tip adapter M6 and M8, dependent on what size tips you're using, but otherwise yes - straight swap/interchangeable in an MB36 torch
8mm ................... 6mm
MB25 are a different adapter all together and have integral gas diffusers instead of the separate ceramic diffuser in the MB36s
if you want to run the MB25 at high currents, fit an M8 adapter and use the M8 tips .... last a lot longer(y)
Thanks Gra. Didn't reply last night, I'd got arc eye.
not nice mate .... 3 a.m. and eyefulls of burning sand ... can't recommend anything for it as I have never found anything that calms it down .......
you got a crack or gap in yer mask ... unusual to be 'self inflicted' .. more normally associated with being around other ppl welding .... or you got bright orange overalls reflecting the light up under your mask ... 's why Proban boilersuits are dark blue ;)
No Gra, from this thread:ROFLMAO:
maz
maz
Damn, now they put the deals up. Just spent several months welding up the defender chassis with my crappy clarke welder. That little thing would have done nicely!
Lincoln Bullet ? great weapon, but noisy without long leads :giggle:
yes Bri
Kempi stuff has always had a decent rep. for the last 30 years, since I can recall seeing them first about, widely. :rolleyes: ... never been inexpensive though :oops:
well look what we have here
unmolested too, still running a dynamo and an original Reyroll 110v socket .... would want to start that, 'fore I parted with cash ... those 4D,s were notorious for porous bores and paper gaskets at the bottom of the liners failing :( .... would want to pay a LOT less than asking if it didn't run
Seems a lot of coin🤔
Not if it’s a good runner and the engine is sound. And you’ve got a lot of big stuff to weld and no three phase. Far better mma welder than any inverter that I’ve used, certainly on 4mm electrodes upwards.
yeh ... take some beating, but for an unknown quantity it's a LOT .... and you'd want a damned good sparky to give it a once over ..... 500 quid'd be a gamble, as it stands there ... running and functional, worth 1500 quid all day
Apart from bearings and brushes, there’s not a lot to wear. Corrosion might be an issue. A nice Perkins 1004 or 4236 in there would Just set it up nicely. If it was a good bit cheaper.
the exciter com.s are prone to expansion through damp ingress when not used for a long time - trust me - been there ;) ... 's a new one job from Lincoln in Welwyn Garden City .... 'least that's where I collected the last one from .. a long time ago :rolleyes:
