I think one of the main reasons lpg isn't as widely used as kero other than cost is the fact that you are tied to a supplier, even though a lot of kero users are probably loyal to one supplier.I’m keeping the house as a rental once I’ve built mine so it is relevant and I’m familiar with kero so i understand how that works . Locally LPG has not been as widely accepted and I’ve also seen a lot of LPG tanks removed hence my scepticism.
Surely there is some way to work out how much more LPG you will burn in comparison to Kero to deliver the same heat in percentage terms . Then that can be multiplied by the price per litre to get a realistic comparison. If it’s close then no point in switching to Kero until boiler plays up but if as I initially suspected that kero works out quite a bit cheaper then It might be better to switch now
I guess the best thing for you is to live with it for a while so you can see what the usage and cost is like. Whatever they may tell you oil boiler technology is still decades old, however they arrange the heat exchanger and have made them condensing appliances the burners are basically as they were over 50 year ago. Gas boilers genuinely did move forward a step with modulating burners provided the rest of the heating system is relatively up to date so potentially lpg could be the cheaper fuel.
I dunno where its at cost wise, years back when parents house was at the point of new boiler etc we went oil rather than lpg mainly because tank installation etc could be done ourselves and cost at the time was less.
