Routy56
As the title suggests all 3 pistons have broken on this machine.
Bit like me at times "pissed 'n' broke"
So the story is that my brother Graham bought this as a none runner project.
It's actually a nice older little micro digger and should 'go again' with some fettling
As delivered on a pallet using a tele handler
Body work looks tidy...
He's stripped it all ready .....
D722 engine block
Three fcuked up pistons....
This photos shows that the 'land' between the rings has broken away and then the rings have broken up.
All three pistons are like this
The clock is showing just over 3000hrs.
The bores are like new with negligible wear ride and honing marks still visible.
No evidence of old loss or overheating.
It simply would not start - no surprise there then Sherlock!
Graham simply plans to replace the pistons (on order) and go from there.
NOW, the big QUESTION for my learned friends on this Forum is:
"What is the usual cause of such a piston failure?"
Perhaps some of you have seen this before
I hope that he can get it running OK, then I'll borrow it for small stuff when I can't get mine on site
D722 engine block
