Kubota with Tiltrotator
four pipe-er is always going to be a compromise for anything other than control of tilt/rotate, simultaneously, by its very nature ...
one supply to each service/function ...
if you need / want a supply to a.n.other function - gripper/hitch/aux supply, it has to come from one or the other's available oil supply, at the cost of forsaking the primary use of that function.
Full fat is one service, split in whichever configuration required, fully proportionally, by a dedicated control system - DC2/whatever, to tilt/rotate/gripper/aux/hitch, with each function having its own prop. feed and thus independent speed control.
or
semi-fat with a single proportional service directed/split, by simple on/off button control of where the supply is directed to - tilt/rotate/gripper/aux/hitch, with each function sharing whatever prop. rate is determined by the supply prop. service's set flow rate
both can supply any number of functions simultaneously, unlike the 4 pipe-er.
finally, there's also the bobby basic, with a non prop. service, controlled by buttons determining which function gets supplied, but it is on/off, immediate full flow - comes in/out with 'a bang' .. but again will support multiple functions simultaneously, with flow shared.
Thomas7740
Thomas7740
Seems reasonable value?
Got a price back for a direct mount ec206 4 pipe - no buckets 15.7k€
I have emailed back saying it would be good to have an option on top hitch and a price for 3 buckets ffs 🤷
Shame you can't buy direct and fit it yourself...... we don't seem to have the specialist fitters that the uk has.
Left hooker
Left hooker
You could ask for supply only
Also if you went the full fat you get ec-oil free
You should be able to fit a 4 pipe yourself (maybe with a bit of help with the wiring from a half-decent digger mechanic) if you are a bit handy and have the support of the supplier at the end of the phone.
@CPS - are you allowed to ‘supply-only’ across the water?…
Left hooker
Left hooker
One good thing was , wires just at bottom of lever for my rotate function have a brake some where where it flexes
Was getting worse with loads of the same fault code ,rotate would stop till I switched off then on again
Because I have dc2 I rang up engcon and over the phone with app got Tim to swap the functions over to the spare roller wires and just required me to manually change them over to the top roller with just a Hitachi key to hand to pop out rollers as had no tools with me and I was good to go and out of the s**t till I find time to track down the broken wire and repair it all while I was out on site
POP to fit a 4 piper :rolleyes:
I'm not sure whether my job warrants ecoil as only have tmk tree shear and I don't think that will work under tilty on a 6t weight wise let alone oil.
After that .....full fat versus 4p, 4p has less to go wrong and we don't have the skilled support round here.
Think I would want a detachable gripper though as that seems too good to miss out on.
If CPS can quote me then crack on 👍
