four pipe-er is always going to be a compromise for anything other than control of tilt/rotate, simultaneously, by its very nature ...
one supply to each service/function ...
if you need / want a supply to a.n.other function - gripper/hitch/aux supply, it has to come from one or the other's available oil supply, at the cost of forsaking the primary use of that function.
Full fat is one service, split in whichever configuration required, fully proportionally, by a dedicated control system - DC2/whatever, to tilt/rotate/gripper/aux/hitch, with each function having its own prop. feed and thus independent speed control.
or
semi-fat with a single proportional service directed/split, by simple on/off button control of where the supply is directed to - tilt/rotate/gripper/aux/hitch, with each function sharing whatever prop. rate is determined by the supply prop. service's set flow rate
both can supply any number of functions simultaneously, unlike the 4 pipe-er.
finally, there's also the bobby basic, with a non prop. service, controlled by buttons determining which function gets supplied, but it is on/off, immediate full flow - comes in/out with 'a bang' .. but again will support multiple functions simultaneously, with flow shared.
or
