went way over mine too???? Sorry mate, over my head.
No, we were too busy reading learned papers about bolt tightening and scraping paint off.Teaching granny to suck eggs?![]()
Just the threadsI like the good old fashion "Should you oil wheel nuts" Debate.....![]()
Not all of us keep that much Vaseline on hand!Try some Vaseline in the gearbox instead
torq multiplier ,hasnt failed yet on anythingJust the threads
Recently had an over ugga Dugga 'ed wheel on one of our trucks from tyre fitters
Our little 3/4 drive got 2 off and wouldn't shift the 8 remaining
Broke the 3/4 t bar with scaff pole trying
Wound up our torque wrench to max to see what they were sitting at and was clicking (bending) at 1000nm
Speak for yourselfNot all of us keep that much Vaseline on hand!
if he was coming from this direction he's either coming from Caparro Tubes, Tafarnaubach IE in Tredegar, or Rodelle Chimneys in Brecon, which'd be my best guess looking at the attached channel on the side of it
Excellent journalism as usual though..... lets shout about the correctly marked and probably correctly indicated rear projection..... but only whisper about the fact that it was actually stopped which was a lack of axles-weight and poor paperwork/route.if he was coming from this direction he's either coming from Caparro Tubes, Tafarnaubach IE in Tredegar, or Rodelle Chimneys in Brecon, which'd be my best guess looking at the attached channel on the side of it
Taking the piss that overhang is ..... "elastic tape officer, only measured 10ft, when I looked at it ... and it's marked "![]()
Yeah bs Wales online againExcellent journalism as usual though..... lets shout about the correctly marked and probably correctly indicated rear projection..... but only whisper about the fact that it was actually stopped which was a lack of axles-weight and poor paperwork/route.
might just've if he'd slewed the other way .......... 'praps?Not walking away from this one!
Always cut the video off at the interesting momentNot walking away from this one!
Probably dug it sheer and it gave way and went for a ride
quite possibly Stu ..... very lucky to end up on his wheels, if that was the case ...... would explain the slurry pile in front of himProbably dug it sheer and it gave way and went for a ride
