Yes, I`ve got an ET24, its about 2.5t. I went for this over the EZ26, for the reasons talked about here, (towing weights).don't Wacker do a 2.4t machine ??
I have a mate who used to have a full arsenal of decals, ahh you need a 30 tonner no problem......I Have Seen this done![]()
My dad's got an old circa 2000 case cx23. Undercarriage is like a 3 tonner with 300mm tracks , full fat counterweight, but arm is a bit smaller, less beefy blade etc. At 2.3t though it's thoroughly capable machine and wish they made a modern equivalent.
3t I guess thenAfter all this, I am still sticking with my Kx71-3. And for that matter, the old Iveco as well!!
The kobelco is big enough that it needs outside help. That is usually with the 6ton dumper.
What I really want is the biggest small dumper I can tow rather than the 1 ton hi tips that I usually end up hiring in rare occasions when needed!!
Depends on the size of your trailerAfter all this, I am still sticking with my Kx71-3. And for that matter, the old Iveco as well!!
Think I'd have a swivel all day long unless just moving muckDepends on the size of your trailer
A 4 ton straight tip is towable weight.
Yes. Although the 2 ton ones are brill. They fit on a gh105 plant trailer, same width as 3 ton digger so will follow where they go and tbh if you have that much to shift that your finding they're too slow compared with a 3 ton dumper your probably best of getting a 6 or 9 ton in anyway.3t I guess then
Swivels are fine if you're never gonna load or unload by hand, far too high for tipping conc out of and no good for making their own road on a tip. 3 ton straight are the optimum balance of size payload and where they'll travel imho. Just beware cos I'm not sure if newer thwaites 3ton are narrower and on smaller wheels than old skool 3 ton?Think I'd have a swivel all day long unless just moving muck
Yeah they are. The new 3 ton thwaites is I think 1650mm wide which is irritating as to wide to be getting on a plant trailer but doesn't really feel hugely bigger capacity than the 2 ton.Swivels are fine if you're never gonna load or unload by hand, far too high for tipping conc out of and no good for making their own road on a tip. 3 ton straight are the optimum balance of size payload and where they'll travel imho. Just beware cos I'm not sure if newer thwaites 3ton are narrower and in smaller wheels than old skool 3 ton?
All UK sold pickups have a 6t gtw except the sangyong musso which is 7t but that has looks only a mother could love plus is unibody as based on their SUV. You can always do a gtw upgrade to bump the others to 7tDidn't realise they had a 6t train weight
Shhh FFS.All UK sold pickups have a 6t gtw except the sangyong musso which is 7t but that has looks only a mother could love plus is unibody as based on their SUV. You can always do a gtw upgrade to bump the others to 7t
Plenty of hitachi zx33u badged as 26sI Have Seen this done![]()
said "Cinderella" not 'Beauty an' the Beast'Did you feature?
Yeah had that on last Thwaites 1Even doing muck shift I prefer swivel skip.
Swivels can build their own stock pile. Some straight tips are so close to the ground and such a shallow tip angle you end up tipping behind the last pile constantly rather than on top.
you can buy stickers you know !My E27 with tilty and grab and oe heavy counterweight is 3000kg on the nose.
View attachment 39098View attachment 39099
When I bought it I was also looking at the Kubotas and asked the dealer if he would sticker up a KX30 as a KX27 for me… He refused - if he’d said yes I’d have bought the machine there and then!
