Bobcat 322
My dad's got an old circa 2000 case cx23. Undercarriage is like a 3 tonner with 300mm tracks , full fat counterweight, but arm is a bit smaller, less beefy blade etc. At 2.3t though it's thoroughly capable machine and wish they made a modern equivalent.
Sounds similar to the kobelco. Essentially a 1.9 on steroids with a fixed track frame.
Just checked and the new eurocomach based case do a 2400kg machine aswell
After all this, I am still sticking with my Kx71-3. And for that matter, the old Iveco as well!!
The kobelco is big enough that it needs outside help. That is usually with the 6ton dumper.
What I really want is the biggest small dumper I can tow rather than the 1 ton hi tips that I usually end up hiring in rare occasions when needed!!
3t I guess then
Depends on the size of your trailer :sneaky:
A 4 ton straight tip is towable weight.
3t I guess then
Yes. Although the 2 ton ones are brill. They fit on a gh105 plant trailer, same width as 3 ton digger so will follow where they go and tbh if you have that much to shift that your finding they're too slow compared with a 3 ton dumper your probably best of getting a 6 or 9 ton in anyway.
Think I'd have a swivel all day long unless just moving muck
Swivels are fine if you're never gonna load or unload by hand, far too high for tipping conc out of and no good for making their own road on a tip. 3 ton straight are the optimum balance of size payload and where they'll travel imho. Just beware cos I'm not sure if newer thwaites 3ton are narrower and on smaller wheels than old skool 3 ton?
Swivels are fine if you're never gonna load or unload by hand, far too high for tipping conc out of and no good for making their own road on a tip. 3 ton straight are the optimum balance of size payload and where they'll travel imho. Just beware cos I'm not sure if newer thwaites 3ton are narrower and in smaller wheels than old skool 3 ton?
Yeah they are. The new 3 ton thwaites is I think 1650mm wide which is irritating as to wide to be getting on a plant trailer but doesn't really feel hugely bigger capacity than the 2 ton.
All UK sold pickups have a 6t gtw except the sangyong musso which is 7t but that has looks only a mother could love plus is unibody as based on their SUV. You can always do a gtw upgrade to bump the others to 7t
Shhh FFS.
Even doing muck shift I prefer swivel skip.
Swivels can build their own stock pile. Some straight tips are so close to the ground and such a shallow tip angle you end up tipping behind the last pile constantly rather than on top.
(y)(y)
Simon edwards
Simon edwards
we run a straight telex 3 ton and have just got jcb (telex) 3 ton swivel and I prefer the swivel in most situations does’nt feel quite as sure footed as the old terex though,that things a bit of a beast and goes pretty much anywhere.
bobthebuilder
