Fuel filtration polishing rig
F
fueldoc
I am making a trolley mounted duplex filtration rig to filter and polish wet and dirty diesel fuel. If you are having fuel problems this is the answer. It is fitted with 2 high capacity filter water separators with elements that can be rated at 30, 10 or even 2 micron filtration , powered by an onboard 12v 24v or 240 volt pump. A totalizer is also fitted to keep track of fuel throughput complete with a vacuum gauge to indicate filter life. comes with a multi page manual - price £750 plus delivery.
I am making a trolley mounted duplex filtration rig to filter and polish wet and dirty diesel fuel. If you are having fuel problems this is the answer. It is fitted with 2 high capacity filter water separators with elements that can be rated at 30, 10 or even 2 micron filtration , powered by an onboard 12v 24v or 240 volt pump. A totalizer is also fitted to keep track of fuel throughput complete with a vacuum gauge to indicate filter life. comes with a multi page manual - price £750 plus delivery. View attachment 38187View attachment 38188
Does it remove dye colour? Asking for a friend.
Not cheap is it, this cleaning fuel lark🤔
T whiting
T whiting
I've got to agree @JD450A I've run a few thousand L of kero through one of those out the bottom of old steel tanks and it looked and went through the boiler fine throuput is a little low though I wish I'd gone for the double filter one
flowfit been selling those sort of set ups for years.... similar sort of bucks IIRC .. looks a tidy job, but you'd want a decent source of contaminated fuel to warrant the cost.
Hi @fueldoc , great idea, but may I offer some constructive criticism?
  • As it stands, it looks like something thrown together on your afternoon off. It needs to look more professional. Welding the rails on and painting would help a lot.
  • As it is, the mounting rails poke out past the trolley frame - this leaves sharp corner that will snag things and rip trousers if you get too close.
  • Having the inlet hose poke out the side almost doubles the width. Consider a Tee between the filters rather than one end and keep it slim.
  • The trolley is only stable in three directions - with the outlet hose out the back, a small tug will cause it to fall over. When that happens (and it will), the meter is likely to be the first point of contact.
  • you need a bail to neatly coil the hoses.
There are other things I'd probably do differently depending on flow ratings of pump vs filters.
If you assume there will be an occasional drip (not to mention what happens when you drain the bowls), the 'foot' will be covered in fuel and will leave a trail as you wheel it around. You need a removable tray to catch any spill.
I wonder if it could be backpack mounted?
F
fueldoc
Thankyou for your comments, some of your suggestions are already in place but I agree not shown in the photographs, there is a removable drip tray supplied. plastic stop ends can be fitted the cover the ends of the mounting bars and your other ideas I will give some thought.
Ok so the pump is now £130
You know it's a chinese pump when the specs are just random numbers
12V and 13A is 156W
If the pump is only 50% of the claimed power, you'd want to check the flow rate to have any confidence you know what you've got.
Justme
12V and 13A is 156W
Seeing as I actually have one I know how quick it can pump the 20L 's at a time I fill by, their 40L per min is about right.
Also it looks the same as the one in the first post.
F
fueldoc
Yes of course its the same unit as on eBay and Facebook market place and other places, why would it not be?
I've chosen the pumps after several experiments with other pumps , be it 240 ac or 12v the pump head unit is the same , its a positive displacement pump with an internal relief valve that will open when the pump is momentarily dead headed, the performance which I checked by my own flow tests using diesel and cooking oil is as RR says adequate for the job in hand .........bearing in mind the filter separates water by gravity you need some dwell time within the filter to allow droplets to fall into the bowl, this is aided by the central static turbine that swirls the fuel and droplets making a vortex to increase droplet size by agglomeration and in the case of gross water the slower the flow the better really.
The aim being to convert unusable fuel into fuel that is free of undissolved water and dirt/slimes and make it fit for purpose once more.
so at that flow rate it may need to be filtered & 'polished' more than once then ?? :unsure:
