Hi
@fueldoc , great idea, but may I offer some constructive criticism?
- As it stands, it looks like something thrown together on your afternoon off. It needs to look more professional. Welding the rails on and painting would help a lot.
- As it is, the mounting rails poke out past the trolley frame - this leaves sharp corner that will snag things and rip trousers if you get too close.
- Having the inlet hose poke out the side almost doubles the width. Consider a Tee between the filters rather than one end and keep it slim.
- The trolley is only stable in three directions - with the outlet hose out the back, a small tug will cause it to fall over. When that happens (and it will), the meter is likely to be the first point of contact.
- you need a bail to neatly coil the hoses.
There are other things I'd probably do differently depending on flow ratings of pump vs filters.
If you assume there will be an occasional drip (not to mention what happens when you drain the bowls), the 'foot' will be covered in fuel and will leave a trail as you wheel it around. You need a removable tray to catch any spill.
