Today's job was sight seeing Elan valley Had a tour through the second dam as the first one they are repairing and have dropped the water down to do the repairs
did you go up to Clarewen dam as well Stu ? 's impressive
" The Claerwen dam was finished in 1952 and was given a late Victorian effect so that it blended in with the earlier dams in the valley. It was necessary to employ the services of Italian stonemasons as British ones were still at work in London during the post-war rebuilding process of the late 1940s.
Downstream face of Claerwen Dam
The dam took six years to complete and was almost twice the size of the other dams in the Elan valley. The Claerwen reservoir is almost the size of all the other reservoirs in the Elan Valley system combined. Officially commissioned by Queen Elizabeth II in 1952, it was one of her first royal engagements as monarch. "
Left hooker
Left hooker
Didn't get round there as visited all Victorian ones and popped in the visitor center for a sandwich, cake and drink 😋
'nother nice run out for you .... stopping at devils bridge (needs a couple of hours for the long walk round)
Left hooker
Left hooker
Gong to Aberystwyth today to ride on the narrow gauge railway and then see the water falls at the end of the line
Picked up a third cut and collect cheap locally ish. Bloke said he’d deliver it, turned out he worked at the next farm down the road up till three years ago!
Added a hydraulic top link without check valves, and I’m using the float on what would be the loader spools. Doing a lovely job. 1.5m rather than the others which are 1.25m and it’s like the tractor doesn’t even know it’s on there.
A few teething problems with the flail but nothing a couple of hours workshop didn’t sort.
L
Lynchy
New machine in site,took day to pipe up,adjust....can only reach 5 anchors,no one got a tape?Low loader will cost more than production
did you notice the abandoned foundations lower down the valley, in the river bed, 'fore you get to the first one .. I understand they intended it as a further reservoir but changed plans
A few teething problems with the flail but nothing a couple of hours workshop didn’t sort. View attachment 38170
you just cutting it or want it yourself ??? how're you collecting it ??
badly in need of attention
Left hooker
Left hooker
View attachment 38176 View attachment 38177
Didn't see that one or the base of that one 🤣
Went on the narrow gauge railway from Aberystwyth up to the devils bridge today
And walked down all the steps to the bottom where my wife had a melt down over the arch bridge to cross the river (she's got a fear of heights and was crying and shaking just at the thought of it ) ordered us not to cross while she went over as to not over load the bridge or shake the bridge 🤣
Water falls were nice and refreshing from the spray due to the climb up to them
yeh that's a pretty flimsy little bridge that, down the bottom ... not for the faint hearted in the height dept. :LOL:
nice pix Stu
It’s a flail collector so it holds it in a box then you drive somewhere to empty it. Usually a nettle patch at the edge!
Here it is set lower doing a cracking job of creeping bramble removal on a nature reserve.
A little Komatsu we fitted a rotate kit too today. We also converted the hammer lines to buttons on the joysticks so that both the hammer/shear and rotate lines are on buttons.
Runs really nice...... and not a CE top in sight 😉😂
Aiden - have you had a close up (under the panels) look at a Bobcat E27 by any chance? The factory supplied second proportional service (controlled perfectly from the factory joysticks) is tee’d into the boom offset (switches over from offset to 2nd service, which is fine). It delivers a very disappointing flow (which I use for rotate) - any clever thoughts as to how to plumb it differently but control it the same and get oil to hose out at a million litres a minute?…
