I'm unsure if the stroke of the rams are long enough, or if it's a sensor.... by f**k i've tried.if it uses a proximity sensor .... add a switch to the circuit .. and turn it off![]()
quite possibly the rams if it isn't rated over the frontI'm unsure if the stroke of the rams are long enough, or if it's a sensor.... by f**k i've tried.
knew I jad a pic of one somewhere .... stunningly clever machinesWorked with this crane last year and it was one of the most impressive I’ve seen, fully remote controlled if needed cab lifts right up and incredibly compact for its size.
I think it's a distinct possibility, annoyingly. The fact it stops dead at 90' to the lorry is a good tell.quite possibly the rams if it isn't rated over the front
unusual not to go past the legs at all though ... usually get 25-30 degs past .... legs behind the hiab or between it and the cab ?? .... if rearward I can understand thatI think it's a distinct possibility, annoyingly. The fact it stops dead at 90' to the lorry is a good tell.
Legs behind the Slew.unusual not to go past the legs at all though ... usually get 25-30 degs past .... legs behind the hiab or between it and the cab ?? .... if rearward I can understand that
no real forward support to speak of then ... just balanceLegs behind the Slew.
Mine has a spool with a stiff wire sticking up that touches a cam on the slew ring (well did haveif it uses a proximity sensor .... add a switch to the circuit .. and turn it off![]()
Zooport railway station?? looks like St Woolos cathedral in the background
Yeah think they are going to lift the new steps in positionZooport railway station?? looks like St Woolos cathedral in the background
well he ain't reeved for a lot, so probably got a reach on with Superlift riggedYeah think they are going to lift the new steps in position
Not the best of photos tbfcould also be a 500, but doesn't look big enough![]()
I’d say definitely 500 with the cab that swings aroundcould also be a 500, but doesn't look big enough![]()
I was trying to decide if it was a swingaway cab or not ... doesn't look to have enough articulation .... it was my first thought, but boom doesn't look big enough eitherI’d say definitely 500 with the cab that swings around
It looks big from the rearI was trying to decide if it was a swingaway cab or not ... doesn't look to have enough articulation .... it was my first thought, but boom doesn't look big enough either
this is a 500t Lieb., max rigged for an on the limit lift in the local hospital in Jan. 2009
View attachment 38007View attachment 38006
looking at those again it's deffo a 500 in Zooport
